Increasing Height Of Washing Machine Standpipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-03-2012, 09:36 AM   #1
Increasing height of washing machine standpipe
The water that fills up the washing machine often drains out before the washing machine can get to the other parts of the washing cycle. I've tried manipulating the drain hose (trying to see if changing the angles at which the drain hose leaves the washing machine would do the trick), but that doesn't solve to the problem. Then I checked the manufacturer's recommended standpipe height: 39". My standpipe height is 28". How can I raise the height of the standpipe?
Agnikan is offline   Reply With Quote
Old 06-03-2012, 09:37 AM   #2
Rewards Points: 13,458
Coupling and a piece of PVC.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Washing machine discharge hose Deck Plumbing 7 01-14-2012 08:15 PM
washing machine standpipe height white29 Plumbing 8 01-14-2012 01:02 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
