Old 12-19-2012, 03:38 PM   #1
Increase Water Pressure At Shower
Im getting ready to run water lines to my new shower. I was just wondering if there is some kind of product that will increase the water pressure coming out of my shower head or is all based off of my pressure tank in my basement? I would love to have pressure like some of the hotel showers that I've used in the past. I am on a well, not city water not sure if that makes a difference.
bigfishcatcher3 is offline   Reply With Quote
Old 12-19-2012, 05:59 PM   #2
Far more important to have enough supply then pressure.
Run 3/4" supplys as close as possible to the valve and you will have all pressure you want.
Picture this, buy a 3/4" garden hose, now stand on the hose and turn it on.
Pressure will still be the same on the incoming side but lower flow on the out coming side.
Old 12-19-2012, 06:24 PM   #3
Master General ReEngineer
Bondo's Avatar
Ayuh,... To add to Joe's comments,... Yes, it's based on the system pressure,...
'n Good Flows,....
Bondo is online now   Reply With Quote
Old 12-19-2012, 06:39 PM   #4
Roofmaster
You can raise the pressure on your pressure switch, but it is all about flow. With a well, it usually depends on how much head your pump is pushing. My well only puts out about 4 GPM, but my pump was installed in 1993, and with my acidic water, it is nearing the end of its life, I am sure. I will jack up the HP when I replace it.
" A lot of men build things, and a lot of things fall down "
Old 12-19-2012, 07:49 PM   #5
Thanks guys
Low water pressure in shower Bluew126 Plumbing 5 08-28-2012 07:47 PM
1 Week Old Shower - Water Pressure Disappeared? ClarendonCondo Plumbing 8 10-18-2009 06:41 AM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 11:53 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
Insane water pressure in shower!!! Sarah24 Plumbing 5 12-09-2008 06:27 AM
