Impossible To Unscrew Brass Check Valve From Well - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-06-2010, 04:54 PM   #1
Rewards Points: 1,062
Impossible to unscrew brass check valve from well
Hi people,
Have a well/pump system with a goulds pump drawing water from the earth. I need to unscrew the check valve (a Parts 2O, poppet style 200psi, 1 1/4" size.) I even heated it up first with propane and then 2 guys with pipe wrenches. Thing will not budge!
I admit, the wrenches are only say, 18" and other is about 24" with exxxxtension pipe. i doubt it would be soldered, eh? I mean, even if it was, wouldnt the propane have softened the solder?Any advice appreciated!
noquacks is offline   Reply With Quote
Old 12-06-2010, 05:22 PM   #2
walt1122
Rewards Points: 334
keep trying! Remove the check valve guts so you don't cook the rubber parts or temper the metal. I've seen food safe penetrating oil that you should be able to use safely around potable water. warm up the parts with propane Not MAP don't want to get the parts that hot. Spray the oil on and gently tap, tap, tap while you try to turn the pieces apart. Worst case yes you may need to cut the one way valve off from the pipe. If you don't have a way to rethread the 1 1/4 pipe carefully hacksaw or grind away slowly the valve making sure you don't mess up the treads on the pipe. I have found that if you cut down the length of the valve in a few places it often helps so you can get the penetrating oil into the threads and or be able to pry the valve away from the pipe. Might want to try moving down the pipe and see if you can remove the lenght of pipe AND valve so you can get it someplace where you can work on it more easily. What is the pipe, galvanized?, brass? Really doubt someone would use solder on the brass or metal solder on the galvanized Shouldn't cook galvanized not good for it or you, just sounds like the pipe dope dried and hardened onto fittings.
Walt
walt1122 is offline   Reply With Quote
Old 12-06-2010, 06:23 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... Get Loonngggeerrr pipe handles...
Bondo is online now   Reply With Quote
Old 12-07-2010, 05:10 PM   #4
Thaks, Walt and Bondo. Thats just what I needed.....good tips. Walt, the well is NOT for drinking....just garden/lawn. It is steel/galvanized. Hey, I could cut carefully with a grinder, if Bondos tip of longer levers dont work. I will get it , dont worry. I'll advise.
Old 12-10-2010, 06:19 PM   #5
just wanted to let yous know....it came off!! Bumped it with a hammer all around, over and over, with a 5lb weight behhind it for support. Bang bang bang.......then propane again...hot as possible, then, with 2 plumbers wrenches.... crack!! It worked!!
Thanks, people
Old 12-14-2010, 03:59 PM   #6
walt1122
Rewards Points: 334
glad to hear you were able to get it to work out for ya'
Old 12-30-2010, 04:18 PM   #7
OK, finally put in some new pvc fittings, as old ones were melted away. So, I primed the pump, and man, pump keeps running when I turn it on as if it wasnt primed right/enough.
What am I doing wrong? Thanks!!
Old 12-30-2010, 04:47 PM   #8
Bondo's Avatar
Ayuh,... More details please,..?? Prime it More,..??
Old 12-30-2010, 04:55 PM   #9
Details? OK: I opened up a "faucet" that gets water from the pump, opened pump inlet valve/faucet, supplied it with water from another donor source, burped the faucet supplied from pump until no more air, closed that, closed spigot at pump, closed donor source water .
With all faucets shut off, turned power on to pump, it runs, and runs, and runs, and.......
Yup, I did this 3 times.
Tanks!
Old 12-30-2010, 04:57 PM   #10
I realize theres not much more one can do. Thats why Im puzzled.
Old 12-31-2010, 10:37 AM   #11
Hmmm, I though I gave enough details. Im stumped, and ready for ideas.....actually, Im desperate for ideas!!
Old 12-31-2010, 10:46 AM   #12
And Still Learning
With all the action above ground level I'm thinking you have developed a leak on the suction line.
Look into the well with a flashlight while adding the priming water. See any waves? or Does the pump accept more prime water after it has been setting for an hour. Once primed even with the plug removed it should only accept so much water.
Know It ALL is offline   Reply With Quote
Old 12-31-2010, 11:48 AM   #13
Rewards Points: 3,130
Does your setup have a pressure gauge somewhere? If the pump never shuts off, there's not enough pressure being developed to actuate the pressure switch.
Old 12-31-2010, 09:19 PM   #14
Household Handyman
Rewards Points: 1,408
Err, Uhh, this sounds to be a "Jet pump", or above ground pump if you can prime it with another water source. Disconnect the piping at the point just before where you installed the new check valve. Start the pump and if it will pump the water, allow it to pump just out into the air for a few minutes to assure it will run adequately. If it does work, then check your piping, something may be in backwards or wrong preventing the water flow.
Old 01-01-2011, 04:29 PM   #15
Thanks, Guys!! It worked (with your help)! BUT, not yeah, I get water/good force, but the pump now wont shut off!! So, hey, we're getting closer, right? Think the pressure tank on top has anything to do with it? I think there should be enough pSI in there...its not that old.....
Other ideas, I dunno.
Thaks!
How to replace the trigger valve on a Bostich Nail Gun. brokenknee How To Guides 10 11-08-2013 12:25 PM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 10:49 AM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 10:06 AM
Jackel Eco Systems DJ-545 check valve pesphoto Plumbing 5 05-20-2008 08:49 PM
