Impossible To Fix Leaky Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2013, 06:44 AM   #1
Rewards Points: 1,062
Impossible to fix leaky faucet
People,
Popped in a faucet on a sink - faucet worked well before on another sink. Now, faucet has a steady drizzle of water. Cold and hot water handles are closed all the way, of course. Why would this faucet, which worked great on another sink drizzle steadily on this sink?
Is it the goose neck base seal or would you suspect the valve at the cold? (hot side is shut off/blocked, as we use cold only here- no hot water tank hooked up).
Thaks
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 06-28-2013, 06:59 AM   #2
Rewards Points: 13,694
It may have picked up some trash in it from the lines being turned on and off.
Take apart, clean it out and inspect.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
noquacks (06-28-2013), RWolff (06-28-2013)
Old 06-28-2013, 07:19 AM   #3
Oh- this may help- it is leaking from base of goose neck as well as from tip/spout. Gotta be a base o ring, right?
Old 06-28-2013, 10:24 AM   #4
Rewards Points: 276
It's possible. As Joe reccommends, clean the cartdrige, aerator, etc. Try taking it apart and putting it back on, maybe o-ring got folded or pinched when you assembled it, etc.
Just be aware, some goose necks don't come apart, (sealed unit), when they start leaking from the base like that, you have to replace whole faucet. What brand do you have? Can you post a pic? Thanks.
jmon is offline   Reply With Quote
Old 06-28-2013, 02:20 PM   #5
Replace it
davidblackwoods is offline   Reply With Quote
leaky shower faucet diy'er on LI Plumbing 3 09-03-2012 05:33 AM
Double Basin Concrete Sink leaky faucet newoldhouse Plumbing 3 05-14-2012 10:25 PM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Leaky Delta bathtub faucet DOW Plumbing 4 01-04-2009 08:33 AM
Quick leaky faucet question JPfixit Plumbing 5 12-09-2008 11:21 AM
