Illinois Code For Dishwasher Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2013, 09:02 AM   #1
Illinois code for dishwasher drain line
Can someone tell me when this code changed to disallow the dishwasher to drain into the disposal? I have a professionally installed dishwasher that I am now being told is hooked up incorrectly. I think it was installed around 2004 or so. We are selling the home and the home inspector has pointed this out. Any estimate on how much to correct?
Angela S is offline   Reply With Quote
Old 05-12-2013, 09:14 AM   #2
Rewards Points: 13,712
Post a picture of what you have now.
Old 05-12-2013, 09:29 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 676
I don't know your code-sorry. Did he say what the requirement is or what he expects?
He may be asking for an air gap between the disposal & DW
Old 05-12-2013, 09:44 AM   #4
I can't figure out how to upload a photo. The dishwasher drains into the disposal above the trap. Inspector said
"The dishwasher was noted to be draining into the garbage disposal. While the disposal is manufactured for this, it is locally considered to be a hazardous cross connection. Recommend correction by a licensed plumber."
Old 05-12-2013, 10:05 AM   #5
Here is the photo
Old 05-12-2013, 10:20 AM   #6
Rewards Points: 1,010
I think a bigger problem is that everything is piped sideways
Anti-wingnut is offline   Reply With Quote
Old 05-12-2013, 10:25 AM   #7
Your assembly doesn't have a airgap, or Johnson Tee or at the minimum, a high loop to prevent siphoning. Here is a web site showing the correct connections using a air gap
http://www.smartplumber.org/garbage_disposal.html
Old 05-12-2013, 10:27 AM   #8
GBrackins's Avatar
Rewards Points: 2,108
here ya go ....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-12-2013, 11:04 AM   #9
Here is the code:
TITLE 77: PUBLIC HEALTH
CHAPTER I: DEPARTMENT OF PUBLIC HEALTH
SUBCHAPTER r: WATER AND SEWAGE
PART 890 ILLINOIS PLUMBING CODE
SECTION 890.770 DISHWASHING MACHINES
Section 890.770 Dishwashing Machines
a) Domestic Dishwasher (Private Residence). When a domestic dishwashing machine drain line is connected to the house side of a trap from a sink, the drain from the dishwasher shall be carried up to the underside of the spill rim of the sink. Dishwashing machines shall discharge separately into a trap or tail piece of the kitchen sink and shall not connect to the food waste disposal unit.
b) Water Supply Connection. The water supply to commercial dishwashing machines shall be connected through an air gap or by means of proper backflow protection, e.g., a non-pressure type (atmospheric) vacuum breaker or a dual check valve backflow preventer assembly (DuC), depending upon the circumstances.
I am just trying to pinpoint when this code was changed so I know if this is the fault of my installer. I am not going to be fixing this.
Old 05-12-2013, 11:07 AM   #10
GBrackins's Avatar
a call to your building department can answer your questions
Gary
Old 05-12-2013, 12:46 PM   #11
Rewards Points: 1,952
Call your local plumbing inspector / building department, What the house inspector is concerned about is the lack of a loop in the dishwasher drain. This prevents your kitchen sink if it blocks from going into the dishwasher. Some models on new dishwashers have the loop tied up to the side of the dishwasher itself. So a loop under the kitchen sink would not be necessary.
Old 05-12-2013, 01:00 PM   #12
Plumber
Rewards Points: 676
With all due respect- If your not going to fix it, what does it matter?
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (05-12-2013), Javiles (05-14-2013)
Old 05-12-2013, 01:09 PM   #13
Why would you think an appliance installer or handy man has any concern with modern day plumbing code? What do they care if your family becomes sick.. You saved money by not using a professional...
Old 05-12-2013, 01:10 PM   #14
Rewards Points: 582
wow really your not going to fix it....call your local code office see when code was changed ....have a good day...sorry guys for your time...ben sr again as mentioned no disrespect but people want advice to fix things....
Old 05-12-2013, 01:32 PM   #15
If you had read my original post you would know that I am selling my home. I am trying to decide how much to credit the buyer or if I should pursue this with the company that installed it. If I was staying in the home I would fix it myself by bringing in a plumber. It is a newer model dishwasher and was professionally installed by a plumber. Thank you all for the advice
Tags
disposal drain
Gas line for pool heater BillyDIY Plumbing 3 06-10-2011 02:29 PM
Sump Pump Drain line keeps freezing jerrylee Plumbing 5 02-25-2011 09:25 PM
Moving a Bathtub Drain Line jhawkdc Plumbing 7 02-22-2011 08:40 PM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
