-   -   Illinois code for dishwasher drain line (http://www.diychatroom.com/f7/illinois-code-dishwasher-drain-line-179362/)
Angela S 05-12-2013 09:02 AM
Can someone tell me when this code changed to disallow the dishwasher to drain into the disposal? I have a professionally installed dishwasher that I am now being told is hooked up incorrectly. I think it was installed around 2004 or so. We are selling the home and the home inspector has pointed this out. Any estimate on how much to correct?
joecaption 05-12-2013 09:14 AM
Post a picture of what you have now.
TheEplumber 05-12-2013 09:29 AM
199 Attachment(s)
I don't know your code-sorry. Did he say what the requirement is or what he expects?
He may be asking for an air gap between the disposal & DW
Angela S 05-12-2013 09:44 AM
I can't figure out how to upload a photo. The dishwasher drains into the disposal above the trap. Inspector said
"The dishwasher was noted to be draining into the garbage disposal. While the disposal is manufactured for this, it is locally considered to be a hazardous cross connection. Recommend correction by a licensed plumber."
Angela S 05-12-2013 10:05 AM
1 Attachment(s)
Here is the photo
Anti-wingnut 05-12-2013 10:20 AM
I think a bigger problem is that everything is piped sideways
Anti-wingnut 05-12-2013 10:25 AM
Your assembly doesn't have a airgap, or Johnson Tee or at the minimum, a high loop to prevent siphoning. Here is a web site showing the correct connections using a air gap
http://www.smartplumber.org/garbage_disposal.html
GBrackins 05-12-2013 10:27 AM
1 Attachment(s)
here ya go ....
Angela S 05-12-2013 11:04 AM
Here is the code:
TITLE 77: PUBLIC HEALTH
CHAPTER I: DEPARTMENT OF PUBLIC HEALTH
SUBCHAPTER r: WATER AND SEWAGE
PART 890 ILLINOIS PLUMBING CODE
SECTION 890.770 DISHWASHING MACHINES
Section 890.770 Dishwashing Machines
a) Domestic Dishwasher (Private Residence). When a domestic dishwashing machine drain line is connected to the house side of a trap from a sink, the drain from the dishwasher shall be carried up to the underside of the spill rim of the sink. Dishwashing machines shall discharge separately into a trap or tail piece of the kitchen sink and shall not connect to the food waste disposal unit.
b) Water Supply Connection. The water supply to commercial dishwashing machines shall be connected through an air gap or by means of proper backflow protection, e.g., a non-pressure type (atmospheric) vacuum breaker or a dual check valve backflow preventer assembly (DuC), depending upon the circumstances.
I am just trying to pinpoint when this code was changed so I know if this is the fault of my installer. I am not going to be fixing this.
GBrackins 05-12-2013 11:07 AM
a call to your building department can answer your questions
Ghostmaker 05-12-2013 12:46 PM
Call your local plumbing inspector / building department, What the house inspector is concerned about is the lack of a loop in the dishwasher drain. This prevents your kitchen sink if it blocks from going into the dishwasher. Some models on new dishwashers have the loop tied up to the side of the dishwasher itself. So a loop under the kitchen sink would not be necessary.
TheEplumber 05-12-2013 01:00 PM
199 Attachment(s)
With all due respect- If your not going to fix it, what does it matter?
Ghostmaker 05-12-2013 01:09 PM
Why would you think an appliance installer or handy man has any concern with modern day plumbing code? What do they care if your family becomes sick.. You saved money by not using a professional...
ben's plumbing 05-12-2013 01:10 PM
wow really your not going to fix it....call your local code office see when code was changed ....have a good day...sorry guys for your time...ben sr again as mentioned no disrespect but people want advice to fix things....
Angela S 05-12-2013 01:32 PM
If you had read my original post you would know that I am selling my home. I am trying to decide how much to credit the buyer or if I should pursue this with the company that installed it. If I was staying in the home I would fix it myself by bringing in a plumber. It is a newer model dishwasher and was professionally installed by a plumber. Thank you all for the advice
