Illegal Plumbing By Home Contractor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 02:11 PM   #46
Originally Posted by btdragon View Post
Part narrowed down:
http://www.centralbrass.com/Document...s/S0607C34.pdf
That is what is in the wall. It SHOULD NOT BE.
NEVERMIND
It is called a wall tile stop. Researching now.
btdragon is offline   Reply With Quote
Old 06-06-2013, 03:31 PM   #47
Roofmaster
Rewards Points: 2,210
Is something not working correctly?
Old 06-06-2013, 04:12 PM   #48
The tile stop valve apparently.
Old 06-06-2013, 04:54 PM   #49
Bill Kearney
Rewards Points: 1,174
Given the age of a lot of metro buildings I wouldn't make ANY assumptions about what some fixtures are supposed to accomplish.
wkearney99 is offline   Reply With Quote
Old 06-06-2013, 05:22 PM   #50
Rewards Points: 2,108
Im pretty sure that New York also requires the Plumber heating and electrical subs to pull permits and get inspected prior to covering. Did any city inspectors come to look?
Old 06-06-2013, 05:32 PM   #51
Rewards Points: 4,796
Originally Posted by TheEplumber View Post
As for permits or plumbing license- As a contractor, If I remove a p trap I need a plumber- yes it's ridiculous and is never followed.
Yeah, it is pretty ridiculous. As a standard rule of thumb, and I believe most states would be OK with, if you stay on the fixture side of the trap to do your work, anyone can do it. For example you certainly don't need a permit to change out the faucet in your bathroom. But then, that rule of thumb really refers to the drain side of plumbing, not the supply side.
Another rule of thumb is that if you don't need to turn off the water supply at the meter (i.e. outside your house), then you don't need a permit. This one sounds a little more suspicious, but at least it refers to the supply side. For example, you can turn off the supply valves under your sink and change out the faucet that way. Of course, you could still do a lot of damage in your plumbing by turning off your house supply with your main shutoff inside your house
jeffnc is offline   Reply With Quote
Old 06-06-2013, 06:10 PM   #52
Plumber
TheEplumber's Avatar
Rewards Points: 914
I realize every state is different, but if a State uses the UPC code- the rules of thumb you reference are wrong. But I don't know anyone who adheres to the "letter of the law"
And I do know a plumber who was fined for changing out a faucet- but there were other issues as well. It was just added to the list of violations.
Here is what the UPC states, several states have adopted this code with minor revisions
103.1.1 Permits Required. It shall be unlawful for any person, firm or corporation to make any installation, alteration, repair, replacement, or remodel any plumbing system by this code except as permitted in Section 103.1.2, or to cause the same to be done without first obtaining a separate plumbing permit for each separate building or structure.
103.1.2 Exempt Work. A permit shall not be required for the following:
103.1.2.1 The stoppage of leaks in drains, soil, waste or vent pipe, provided however that should any trap become defective and it becomes necessary to remove and replace the same with new material, the same shall be considered as new work and a permit shall be procured and inspection made as provided in this code.
103.2.2 (1) The clearing of stoppages...
(2) the repairing of leaks in pipes, valves or fixtures, provided such repairs do not involve or require the replacement or rearrangement of valves, pipes or fixtures.
Contractor indicted on tax evasion & illegal payments to a Government employee gregzoll Off Topic 0 01-25-2013 11:48 AM
Contractor Dispute Durt Ferguson General DIY Discussions 8 06-21-2011 09:55 AM
Choosing a contractor Grumpy Remodeling 7 04-28-2011 07:29 AM
Licensed Plumbing Contractor in S.C. jrplumbing74 Introductions 1 04-21-2009 05:01 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
