Illegal Plumbing By Home Contractor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-06-2013, 10:04 AM   #31
Originally Posted by jagans View Post
There appears to be an Air chuck fitting? to the left of the spot from your spotlight in post 18. What the heck is that?
Do you have a dishwasher? Maybe the third valve is for the dishwasher?
It is the look at the valve without the Central fixture on top of it in the other picture with the valve cover removed.
btdragon is offline   Reply With Quote
Old 06-06-2013, 10:20 AM   #32
http://www.gharexpert.com/articles/P...pipe-li_0.aspx
I can't identify what type of valve it is, but it seems to be hooked up on the same line the faucet AND tub uses.
Old 06-06-2013, 10:46 AM   #33
Plumber
TheEplumber's Avatar
Rewards Points: 682
In post 19 you have 2 silver items. The lower one I assume is the valve in question.
What does the top item feed and what does it say on the face?
Old 06-06-2013, 11:06 AM   #34
Top item feeds the sink and is a brassmaster shutoff valve. Bottom item says Central on it and someone said it looks like a cover for an old shower diverter.
Old 06-06-2013, 11:11 AM   #35
Plumber
Rewards Points: 682
Originally Posted by btdragon View Post
Top item feeds the sink and is a brassmaster shutoff valve. ....
Do you have independent hot and cold supply lines going to the sink or just one?
How about the tub? 1 or 2 handle
Old 06-06-2013, 12:23 PM   #36
Architectural Sculptor
RWolff's Avatar
Rewards Points: 502
Is it possible to edit topic without reposting?
Have I been a victim of illegal plumbing?
It is possible to re-edit yes, for a certain time period, I think it's around 24 hours.
Illegal plumbing? I guess I think if it works ok, doesn't leak or cause trouble, does your town now have a plumbing police department who does door-to-door plumbing checks on people's homes searching for illegal plumbing so they can fine or arrest people now?
If it's work you paid for, there's remedies for getting what you paid for, but if it's existing in a house you bought and works fine, why worry about the "plumbing police" pounding on your door at 3am demanding to see your drain pipes, aint gonna happen!
Sculpture scholarship recipient, 2008
Asbestos information: http://www.diychatroom.com/f98/asbes...pt-1-a-181840/
RWolff is offline   Reply With Quote
The Following User Says Thank You to RWolff For This Useful Post:
jagans (06-06-2013)
Old 06-06-2013, 01:12 PM   #37
1 handle tub and 1 handle sink. 2 stop valves under sink so hot AND cold supply.
Other valve affects the faucet AND tub supply.
Old 06-06-2013, 01:24 PM   #38
concretemasonry's Avatar
Rewards Points: 2,608
Being licensed is no guarantee the the work will meet the code. Does he have insurance and liability? A license is just a municipal document based on experience and some financial; ability.
Dick
concretemasonry is offline   Reply With Quote
Old 06-06-2013, 01:25 PM   #39
Plumber
Rewards Points: 682
What I think you have there is a thermostatic mixing valve. This controls the max temp. for your hot water.
Ask your maintainance people to look at it and verify it works right.
As for the contractor- I suggest you politely discuss the issues with the parties involved. I doubt anyone here can advise you on specific NY plumbing or contractor laws
As I said earlier, from the pictures I don't see any code violations- maybe a little sub par workmanship- but that is discretionary and open to opinion.
Old 06-06-2013, 01:46 PM   #40
part is not a thermostatic mixing valve. Temperature does NOT change.
It looks like a Central Brass DIVERTER in the wall.
Old 06-06-2013, 01:47 PM   #41
It is pushing around the water inside the wall, and affecting the water + pressure. I don't know what exactly he did.
Old 06-06-2013, 01:50 PM   #42
Central Brass, 500 6121 521 HC Chrome Tub & Shower Faucet Handle Hot & Cold Set
Old 06-06-2013, 01:51 PM   #43
He stuck on a Tub and Shower Faucet Handle. That should NOT be under the sink.
Old 06-06-2013, 02:07 PM   #44
The model # on the back of the handle is 521-DBW
D is a diverter part.
Old 06-06-2013, 02:08 PM   #45
Part narrowed down:
http://www.centralbrass.com/Document...s/S0607C34.pdf
That is what is in the wall. It SHOULD NOT BE.
Contractor indicted on tax evasion & illegal payments to a Government employee gregzoll Off Topic 0 01-25-2013 11:48 AM
Contractor Dispute Durt Ferguson General DIY Discussions 8 06-21-2011 09:55 AM
Choosing a contractor Grumpy Remodeling 7 04-28-2011 07:29 AM
Licensed Plumbing Contractor in S.C. jrplumbing74 Introductions 1 04-21-2009 05:01 AM
Pay GC to construct home and finish it myself? L O N G . . . Badfish740 Off Topic 9 07-27-2007 08:44 AM
