If The Main Water Valve Is Cut Off Should The Water Heater Be Cut Off Too? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-19-2011, 03:52 AM   #1
If the main water valve is cut off should the water heater be cut off too?
I have a problem in one of my bathrooms where water is streaming from the bathtub faucet. I have a plumber coming the next day. Meanwhile, so I don't continue to waste water I've turned it off. My concern now is whether or not the water heater needs to be shut off as well.
annetter is offline   Reply With Quote
Old 10-19-2011, 06:16 AM   #2
DIY staff
Rewards Points: 7,174
Turn the water heater to vacation---or pilot---if you do turn it off remember to have the plumber relight it for you.
Old 10-19-2011, 09:59 PM   #3
Rewards Points: 1,440
It is a good idea to turn the water heater heat off (turn gas heater control to Pilot) whenever the water supply is shut off. Have a hot faucet running water before turning the heat back on.
This prevents damage to the heater if for some reason the tank should empty out. Electric water heater elements can be damaged if the tank is only partly emptied.
AllanJ is online now   Reply With Quote
Problem with pressure release valve in hot water heater? da_man Plumbing 3 08-16-2011 09:14 AM
Leaking T&P Valve on water heater secutanudu Plumbing 22 07-06-2010 06:02 PM
Water heater keeps leaking out of TPR valve knac1234 Plumbing 10 08-14-2009 09:08 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
