-   -   If the main water valve is cut off should the water heater be cut off too? (http://www.diychatroom.com/f7/if-main-water-valve-cut-off-should-water-heater-cut-off-too-120547/)
annetter 10-19-2011 02:52 AM
I have a problem in one of my bathrooms where water is streaming from the bathtub faucet. I have a plumber coming the next day. Meanwhile, so I don't continue to waste water I've turned it off. My concern now is whether or not the water heater needs to be shut off as well.
oh'mike 10-19-2011 05:16 AM
Turn the water heater to vacation---or pilot---if you do turn it off remember to have the plumber relight it for you.
AllanJ 10-19-2011 08:59 PM
It is a good idea to turn the water heater heat off (turn gas heater control to Pilot) whenever the water supply is shut off. Have a hot faucet running water before turning the heat back on.
This prevents damage to the heater if for some reason the tank should empty out. Electric water heater elements can be damaged if the tank is only partly emptied.
