Old 10-05-2008, 01:10 PM   #1
DIY'er
jamiedolan's Avatar
Identifying size of Black Iron Pipe
Does anyone have a chart for black iron pipe that shows the O.D., so I can identify the size of pipes I am looking at?
For example one pipe I measured is 1 - 5/16, would this be 1" pipe or 1-1/4" pipe?
Jamie
jamiedolan is offline   Reply With Quote
Old 10-05-2008, 04:06 PM   #2
Electrician
SD515's Avatar
Jamie...I googled "black pipe dimensions" and found this page. See if this helps..... http://www.chilipepperapp.com/pipe_w...dimensions.htm
Kyle
Old 10-06-2008, 01:39 AM   #3
DIY'er
jamiedolan's Avatar
Thanks, I missed that page when searching and kept coming up with stuff that only showed the i.d.
You page confirmed that I have 3/4 and 1 inch pipe and no 1-1/4 pipe. I also was able to confirm today that my meter is only capable of 250,000/BTU /HR unless it is upgraded.
So I learned alot of useful information today. I was able to buy a number of the correct fittings (hopefully I got all the correct ones) this evening for the corrections to and the additions to my black iron natural gas piping system.
Thanks guys!
Jamie
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-18-2009 12:18 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
smoothening cut cast iron pipe before mounting fernco coupling amakarevic Plumbing 6 11-15-2007 06:39 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
Threading black iron pipe? sandyman720 Plumbing 3 03-12-2007 07:50 PM
