Identify A Pipe For Me? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-13-2012, 10:37 PM   #1
Rewards Points: 57
Identify a pipe for me?
I am sprucing up my garage and found a 3/4" pvc pipe that runs into the ground/slab. It has been capped and is bone dry inside. It is near my washing machine which is on the opposite of the wall in a laundry room if that helps. I have absolutely no idea what this could be...any thoughts? It was run under a little raised platform for my furnace and the capped end was left exposed almost as if they were planning on having a sink in the garage or something, but I would think that 3/4" would be too small for a drain.
SMRcalidiv is offline   Reply With Quote
Old 02-13-2012, 10:43 PM   #2
Rewards Points: 13,748
Condinsate drain, water softner drain, who knows.
Old 02-16-2012, 10:11 AM   #3
Rewards Points: 150
Conduit for electrical?
psilva8 is offline   Reply With Quote
Old 02-16-2012, 10:37 AM   #4
Rewards Points: 57
I think it might be the original condensate drain for the original ac. My current drain pipe runs along the wall in the same vicinity as the unidentified pipe. I'm now thinking that when I bought the house, and had a new ac installed as part of the deal, that the guys rerouted the drain pipe.
I'm thinking a scope would be the only way to know for sure at this point??
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-25-2012 11:58 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
