Ideas Please. Washing Machine Discharge Line> - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-04-2011, 11:00 PM   #1
Automotive Enthusiast
Sellncars's Avatar
Send a message via AIM to Sellncars Send a message via Yahoo to Sellncars
Ideas Please. Washing machine discharge line>
Hey everyone,
My washing machine is right next to a double laundry sink. The guys that installed it just zip tied the discharge hose on the sink, needless to say it moved one day. I know good time to clean the concrete floor. For now i did the unthinkable ( chain and paper clip binders. LOL, i know ( Ghetto ). Whats the best way to either attach it to the sink like it is run, or whats the best way?
Sellncars is offline   Reply With Quote
Old 09-05-2011, 03:24 AM   #2
Rewards Points: 6,652
Who did you hire to install this?
Old 09-05-2011, 09:33 AM   #3
Rewards Points: 1,448
Get some 2 inch white PVC pipe to be a sleeve to insert the washing machine hose into and hold the hose in position pointing down into the sink. You wil have to find or have or install something nearby to fasten the PVC pipe to. You can put a T joint (PVC pipe) in the middle of that sleeve to provide some extra material (the stem of the T) to make it easier to fasten the sleeve onto a support outside the tub.
Even if the washing machine hose goes all the way through the sleeve which stays dry inside, use glue if it takes multiple pieces (like the T fitting in the middle) to make up this sleeve assembly. You don't want it to come apart at some random time.
AllanJ is online now   Reply With Quote
Old 09-05-2011, 09:49 AM   #4
Rewards Points: 1,574
Try:
http://quinbyhardware.com/Products/S...YER/FERNCO-INC
bob22 is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
