Icemaker Saddle Valve Removal - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-09-2011, 12:02 PM   #1
Meep!
Joe Dirt's Avatar
Icemaker saddle valve removal
Ok, so now that I'm sick of painting for now, I'm going to try some other small projects to get the roller out of my hands for a day.
First on the list is removing the saddle valve from the water line, and replacing it with a proper line with a shutoff. It currently has only the shutoff on the saddle valve itself, and copper line running to the fridge.
Am I correct in my reading that all I really need is to install a tee, with a 3/8 x 3/8 x 1/4 outlet, 1/4" valve, and fittings to connect everything?
Joe Dirt is offline   Reply With Quote
Old 11-20-2011, 08:47 PM   #2
Rewards Points: 211
I did something similar, replacing a saddle valve with a T and ball valve that leads to a quarter inch copper compression fitting that went to my furnace humidifier. You can read about it here: Easiest way to go from 1/2" ball valve to 1/4 inch compression fitting? .
I wanted a ball valve for a shutoff, which complicated matters. If you're OK with a regular compression shut off valve, you should have an easier time than I did.
Studly is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
What should I do with this old saddle valve? darsunt Plumbing 4 06-14-2011 11:16 PM
Re-installing saddle valve on newly installed water heater connections bkraz Plumbing 18 12-16-2010 03:51 PM
can I runa second line from a pre-existing saddle valve? ClancyKev Plumbing 1 10-23-2009 07:02 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
