Icemaker Lines Colors - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-17-2009, 03:21 AM   #1
Rewards Points: 278
Icemaker lines colors
I am having bad luck with the clear 1/4" ice maker lines when used in a 1/4" barb. It seems they always split after a few weeks or months. Are they only meant to be used in the John Guest type fittings? It doesn't help that I am currently using my faucet adapter for my RO unit but it has a barb on it only.
It seems that the colored RO water lines are not as fragile. Is this correct?
DIYGST is offline   Reply With Quote
Old 01-17-2009, 02:16 PM   #2
Rewards Points: 16
Are you talking about pex or just clear plastic tubing? All the icemaker lines i have seen in my area are copper.
ponch37300 is offline   Reply With Quote
Old 01-17-2009, 05:05 PM   #3
Rewards Points: 270
I am using hard translucent plastic. I think it might be PEX? It works fine. Got it at sears hardware.
pcampbell is offline   Reply With Quote
Old 01-17-2009, 07:37 PM   #4
Rewards Points: 85
I'd go with copper tubing. Not much chance of leaking unless punctured. That plastic stuff will not hold up as well. Could be a real nightmare if your not home and a leak develops.
rredogg is offline   Reply With Quote
Old 01-17-2009, 07:54 PM   #5
Rewards Points: 16
I have seen pex in three colors, red, blue, white(it's a frosty white color). I have never seen translucent pex. I would check somewhere other than sears for plumbing supplies. If it is pex you should be crimping it on to barbed fittings. Do a search on pex because i don't think that is what you are using. A picture would really help determine what it actually is.
Old 01-18-2009, 09:05 AM   #6
You may just be dealing with different grades of tubing. Some water fixtures a few years back used coloured versus clear to indetify multiple linesin spouts but I don`t think there was any benefit beyond id, however different rigid pipe manufacturers today clearly use different grades of plastics and vigin versus non virgin pvcss so flex is likely the same quality wise.
Is your tubing splitting at the saddle valve , is that the barb you refer to or elsewhere up the line. I have a spare kit from Watts for future relocation and similar on my humidifier. Never had an issue with my opague lines except discoloration.
Chemist1961 is offline   Reply With Quote
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 03:07 PM
Sites to "virtually" change paint colors? Shpigford Painting 3 11-02-2007 07:10 PM
Blue Chalk Lines on concrete Triple L Flooring 3 10-09-2007 06:50 AM
Ideas for shutter colors for sterling grey siding. patt Painting 1 05-23-2007 08:21 PM
increasing washer supply lines to 3/4" instead of 1/2" amatchin Plumbing 3 04-15-2006 05:23 PM
