Icemaker Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-18-2009, 12:18 AM   #1
Rewards Points: 278
icemaker connection
The refrigerator has a 1/4" compression.
I see the store sells an icemaker "kit", one is clear 1/4" plastic line, another one is like a braided PVC hose line, I was wondering which one is better?
I am using a reverse osmosis system so the 1/4" plastic line would tee right in after the filters, but is the connection using this kind of tube reliable behind the fridge?
DIYGST is offline   Reply With Quote
Old 02-18-2009, 07:45 AM   #2
RippySkippy's Avatar
I've never cared for the plastic lines, had too many leaks in the past. I only use and recommend 1/4" flexible copper.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 02-18-2009, 08:14 AM   #3
Learning by Doing
Leah Frances's Avatar
I use an RO setup to my ice maker using plastic lines. I used some white push in connectors. Make sure to add a shut off valve to the feeder line to the ice maker. It makes life alot easier if you need to shut anything off.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-18-2009, 08:56 AM   #4
MasterPlumber
ironrange's Avatar
Look for a 1/4" Stainless Steel braided line, much better. Copper will kink and leak, plastic will get brittle.
ironrange is offline   Reply With Quote
Old 02-18-2009, 11:32 AM   #5
Rewards Points: 278
Thanks,
what kind of hose is inside the braided lines? Is it rubber and is it going to give a strange taste to the ice?
Old 02-18-2009, 01:30 PM   #6
MasterPlumber
ironrange's Avatar
Thanks,
The inside is made of different kinds of materials depending on what brand you use. They are all approved by the UPC, all safe for drinking water.
Old 02-18-2009, 04:57 PM   #7
Rewards Points: 278
IronRange thanks for the help, is it like this one here?
http://www.hardwareandtools.com/invt/1136845
I hope they sell it locally.
Any ideas how to convert the other end from 1/4" compression female to my 1/4" RO plastic lines
Old 02-18-2009, 06:10 PM   #8
MasterPlumber
ironrange's Avatar
You could use a 1/4" compression coupling, the 1/4" braided flex would screw on one side (remove the nut), the other side would slide over the plastic using the compression nut.
Old 02-18-2009, 07:32 PM   #9
35 YEAR MASTER PLUMBER
MACPLUMB's Avatar
Ice maker line
BE SURE TO USE THE BRASS OR PLASTIC INSERT INSIDE THE COMPRESSION FITTING
JERRYMAC@UTAHWEB.COM
35 YR. MASTER PLUMBER WITH PH.D IN WATER HEATERLOGY, MASTERS DEGREE IN DRAINLOGY,
PLUMB ANY PIPE, SNAKE ANY DRAIN, MAKE COLD WATER BOIL ON A FREEZING DAY
MACPLUMB is offline   Reply With Quote
Old 02-18-2009, 08:32 PM   #10
Rewards Points: 278
Yup, I learned that one the HARD way :P
Old 12-28-2009, 11:28 AM   #11
Remember when using compressions fittings; the ferrul must be equivalent or harder material than the tubing itself. You can not use a plastic ferrul with copper tubing.
Wildwr is offline   Reply With Quote
Old 12-28-2009, 08:16 PM   #12
Household Handyman
Rewards Points: 1,408
I never liked plastic lines, never found one that could not loose that "plastic" taste. I used copper until they came out with the white flexible braided lines, and then some of those would not lose that "taste". I like copper and it has been dependable for me. I now like the stainless braided lines best. Jerry's right, if you use any of the plastic lines, use the inserts made to go inside of the end of the line or the compression will not work properly. I also recommend a filter installed along with these icemaker lines. Good Luck, David
Old 12-29-2009, 05:20 AM   #13
Filter for Ice maker
Does anyone have any suggestions for a filter and possibly a web link showing a particular model?
Old 12-29-2009, 04:50 PM   #14
I only use copper like #2 stated.
If you install it properly you never have to worry about it being brittle and kinking, it last forever.
The way you install it is the key you must use a roll with about four or 5 coils when you pull the refrigerator out for cleaning and service it uncoils like a slinky when you push it back it coils back up.
I also like to cut in a tee with valve arrangement , I hate them little piercing valves they always seem to leak or cause problems.
SULTINI is offline   Reply With Quote
Old 12-30-2009, 05:59 AM   #15
I totally agree with you, I hate those self piercing valves.
It's a little more work adding a copper tee and proper shutoff valve but well worth it in the long run.
I installed a new humidifier about a month ago on my furnace and I tee'd in a proper shut-off valve.
Still waiting for someone to respond on a inline water filter for the ice maker line.
Kitchenaid icemaker jack14246 Appliances 1 12-18-2008 04:06 PM
Whirlpool Icemaker Stopped Working jablizz General DIY Discussions 1 07-19-2008 08:38 PM
whirlpool icemaker problem pbl1962 Appliances 2 12-26-2007 02:07 PM
