Ice Maker Waterline - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-21-2010, 01:25 PM   #1
ice maker waterline
So, this may darn well be a ridiculous idea but here goes. I was hoping to run a water line to my fridge for the ice maker etc. The fridge is opposite the sink and water supply with a walkway between on either side. So I cant just go through the cabinets. In an effort to avoid going over the attic or into the downstairs ceiling, can I
A, take the transition strip that connects the laminate flooring to the original hardwoods, and run a dado through the underside and place the water line in this dado to pass it across the hallway?
B, or heck could i just pull up one of the boards from the flooring and cut a dado in that and repeat?
Ridiculous yes?
B
b_corwin is offline   Reply With Quote
Old 04-21-2010, 04:19 PM   #2
Rewards Points: 1,216
Pick up the water supply from the basement and run it up through the floor to the back of the reefer.
You'll be glad you did some day.
COLDIRON is offline   Reply With Quote
Old 04-21-2010, 05:09 PM   #3
Rewards Points: 530
If you have a downstairs finished ceiling covering the pipes, you might consider doing something similiar to what you suggested. I have mine run behind cab's and across a narrow space to the fridge, but the space is against the outside wall. I know it is not professional, but it is mine. Heheh, I'll get around to hiding it....someday.
If I used a transission strip across a walkway, I would be careful not cut the dado too deep and leave the wood too thin to provide adequate strength. This may not be a really big concern considering how thin the dado will be and if the strip is firmly attached on both sides along its length. Just something to think about.
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-24-2008 11:14 PM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 05:28 AM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 09:27 AM
GE mechanical ice maker failure? ktkelly Appliances 2 04-08-2007 04:26 PM
