Ice Maker Water Line Clogged - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2010, 10:49 PM   #1
Ice maker water line clogged
The water line to the refrigerator is clogged in the plastic tubing that comes out of the saddle valve. So no water comes to the fridge. Is there a way to unclog it?
I also read that it's not worth to use saddle valve (realized it now) and use a stop valve instead. Is that something that can be done without a plumber?
Thanks for your responses.
Dan25 is offline   Reply With Quote
Old 01-01-2011, 12:57 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 348
Your best bet is to use the forum's search feature located in the menu bar. There are a couple of threads here that discuss the pros and cons of saddle valves.
When you replace the the valve run new tubing to your ice maker.
Old 01-01-2011, 09:29 AM   #3
Rewards Points: 1,418
If you want to take the trouble to ream out the plastic line, you could, although you may find it more convenient to replace that plastic line.
If the saddle valve is already there and still works and does not leak, you might as well leave it there. A common problem is sediment clogging the valve as opposed to the line that follows it.
tapping water line for new line KarlJay Plumbing 5 07-28-2010 10:30 AM
Water leak, over 1 gallon every 5 minutes. carl1864 Plumbing 13 01-15-2010 01:31 PM
water pouring into basement from around water supply line matty8199 Building & Construction 29 12-29-2009 06:07 PM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
