Ice Maker Water Hammer - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-23-2010, 09:39 PM   #1
Rewards Points: 81
The water supply to my ice maker is via a small copper tube. This tube runs through the floor into the laundry room below which is tapped into a 1/2" copper cold water pipe via a saddle valve. How do I eliminate the water hammer? Do I install a mini-rester in the 1/2" cold water pipe before the saddle valve or .....???
cougar01 is offline   Reply With Quote
Old 03-23-2010, 11:48 PM   #2
Replacing the "small copper tube" with a larger copper tube can help.
Water hammer is caused when high energy moving water is suddenly stopped by the closing of a valve. Because the energy in moving water increases by the square of the speed, slowing the water down greatly reduces its energy. Larger pipes mean slower moving water.
HooKooDooKu is offline   Reply With Quote
Old 03-24-2010, 06:52 AM   #3
Rewards Points: 1,216
I seriously think it's another problem not the ice maker line the water flow through the ice maker water make up line is minimal in a 1/2 inch water line is a pin hole saddle valve I would look somewhere else for the noise producing hammer. Washing machine could be the main culprit.
I wouldn't increase the size of the line.
COLDIRON is offline   Reply With Quote
Old 03-25-2010, 11:37 AM   #4
Rewards Points: 81
Thanks for the replies! Upon further investigating, I found that the tubing was not secure against the joist. I secured it with a couple of clamps, and the noise is gone. Apparently, the tube was banging against the joist when the water would quickly shut off and echo through the house.
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 08:35 AM
Do water hammer arresters really work? Red Squirrel Plumbing 2 10-25-2009 08:59 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 01:02 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-06-2008 11:31 PM
