-   -   Ice Maker Water Hammer (http://www.diychatroom.com/f7/ice-maker-water-hammer-67468/)
cougar01 03-23-2010 09:39 PM
The water supply to my ice maker is via a small copper tube. This tube runs through the floor into the laundry room below which is tapped into a 1/2" copper cold water pipe via a saddle valve. How do I eliminate the water hammer? Do I install a mini-rester in the 1/2" cold water pipe before the saddle valve or .....???
HooKooDooKu 03-23-2010 11:48 PM
Replacing the "small copper tube" with a larger copper tube can help.
Water hammer is caused when high energy moving water is suddenly stopped by the closing of a valve. Because the energy in moving water increases by the square of the speed, slowing the water down greatly reduces its energy. Larger pipes mean slower moving water.
COLDIRON 03-24-2010 06:52 AM
I seriously think it's another problem not the ice maker line the water flow through the ice maker water make up line is minimal in a 1/2 inch water line is a pin hole saddle valve I would look somewhere else for the noise producing hammer. Washing machine could be the main culprit.
I wouldn't increase the size of the line.
cougar01 03-25-2010 11:37 AM
Thanks for the replies! Upon further investigating, I found that the tubing was not secure against the joist. I secured it with a couple of clamps, and the noise is gone. Apparently, the tube was banging against the joist when the water would quickly shut off and echo through the house.
