Ice Maker Or Water Filter Stop Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2012, 10:53 PM   #1
Rewards Points: 366
ice maker or water filter stop valve
Was wondering what this exact part is called and where one can find it as a standalone part. Is it sold in Home Depot or Lowes? I haven't noticed seeing it around those stores before, or they're not situated to be easily found.
I have this at my home to stop flow of water from water line to water filter. Nice part that I like.
https://www.dropbox.com/s/bvdrjbm0nd...rStopValve.jpg
daluu is offline   Reply With Quote
Old 11-06-2012, 11:00 PM   #2
Rewards Points: 13,300
Looki in the plumbing area where the Shark Bite fittings are.
Old 11-07-2012, 06:35 AM   #3
Rewards Points: 1,216
Why do you ask? Have you checked it to make sure it shuts off by closing it and disconnecting the outgoing side?
Have you checked where it connects to the main to see if there's another valve there to shut it off.
Sorry abut the questions just trying to save you aggravation and $$$.
PS Remember when you first disconnect it there will be residual water in the line that comes out.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 11-07-2012, 07:12 AM   #4
Rewards Points: 752
That looks to me like an item that might have been sold with the water filter system and that exact valve won't be found on the shelf in a plumbing supply.
BTW, thanks for the pic. That makes attempting to be helpful much easier.
Old 11-07-2012, 08:22 AM   #5
http://www.buydirectwaterfilters.com...l_by_1-zs-4_ql
May want to also Google, Whale, and Lasco.
Old 11-07-2012, 12:14 PM   #6
Rewards Points: 366
I do realize that part may be part of the water filter kit. It is just that its a nice part standalone for Diy projects. This is first time I've seen that kind of part.
The plumbing for that does have main shutoff at the tee where it branches off the cold water supply in kitchen, but not very accessible, so this 2ndary valve helped when we replaced filter system with diff type, keeping this existing valve intact.
Old 11-07-2012, 12:52 PM   #7
Special User
Rewards Points: 1,230
I got valves like that for my RO system at either Lowes or Home Depot. You're looking for "JG" or "John Guest" fittings for "PE" or "Poly-Ethylene" tubing. Typically 1/4" is the only size the come in.
tylernt is offline   Reply With Quote
Old 11-07-2012, 09:44 PM   #8
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
That is a 1/4" Murlock valve. I keep a couple on my truck. Murlock (brand) fittings (aka around here as push-pull fittings) are available in a few plumbing supply houses here. I'd imagine they would be available wherever you are too. If not, they can be ordered through the supply house.
JDC is offline   Reply With Quote
Old 11-07-2012, 10:05 PM   #9
Rewards Points: 636
john guest
http://www.johnguest.com/
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 06:26 PM
Hot Water Heater Pleesehelpme Plumbing 8 07-18-2012 09:17 PM
No hot water past the valve at top of hot water heater-?- Daulton Plumbing 4 04-03-2011 03:47 PM
main cutoff valve does not stop water completely lpbaraldi Plumbing 12 09-07-2010 10:46 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 11:02 AM
