Old 12-02-2012, 12:11 PM   #1
ice maker kit
I'm installing new fridge- Instructions say not to use those small "self-piercing" tap in's- Is there a reason why? How do I tap into the line then?
Huskyfan68 is offline   Reply With Quote
Old 12-02-2012, 12:52 PM   #2
JOATMON
ddawg16's Avatar
ice maker kit
You tap into the line like most people do....with one of those kits they say don't use.
I used one....no issues.....in about 6 months I will be moving the fridge and when I do I'll be providing a real valve for it....
Those piercing valves can leak......so I assume that it's the 'safe' postion that the manfg is taking.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
Old 12-02-2012, 02:40 PM   #3
ice maker kit
On mine, after the stop valve, a T was put in the 3/8" line to the hot water side of the sink. The supply line to the ice maker comes off of the T with copper tubing and quickly transitions to 1/4" via a brass reducing compression coupling. Right or wrong it works and has for 30 years.
Fairview is offline   Reply With Quote
Old 12-02-2012, 08:15 PM   #4
ice maker kit
Remove old shut off and install one of these.
http://www.amazon.com/dp/B007FMTCXW/...SIN=B007FMTCXW
Old 12-02-2012, 09:13 PM   #5
call me E
TheEplumber's Avatar
ice maker kit
That's what I have done- but I found these are good too. They go on top of the existing stop
http://www.plumbingsupply.com/quick-tee-adapter.html
Old 12-03-2012, 09:44 AM   #6
ice maker kit
Thanks- I will replace it (not a fan.)- The cold water supply runs directly behind where the fridge is in the basement- Is there a way to install this angle valve directly into the cold water line? (I realize I will have to shut the water off)- but it's easier to tap in there (and closer) then to try to connect it to where the kitchen sink is
Old 12-03-2012, 01:01 PM   #7
Special User
ice maker kit
Would this work? Get yourself a gate valve with compression fittings and an integrated drain. Cut the pipe behind the fridge (removing a short section) and install the gate valve to bridge the gap. Remove the drain cap and install an adapter fitting to go from the drain to whatever your icemaker needs.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 04:20 PM
whirlpool GS6SHEXNS00 ice maker not working houseof5dogs Appliances 1 05-06-2011 09:28 PM
Ice Maker Not Getting Water sgorak General Discussion 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
