-   -   ice maker kit (http://www.diychatroom.com/f7/ice-maker-kit-165366/)
Huskyfan68 12-02-2012 11:11 AM
ice maker kit
I'm installing new fridge- Instructions say not to use those small "self-piercing" tap in's- Is there a reason why? How do I tap into the line then?
ddawg16 12-02-2012 11:52 AM
You tap into the line like most people do....with one of those kits they say don't use.
I used one....no issues.....in about 6 months I will be moving the fridge and when I do I'll be providing a real valve for it....
Those piercing valves can leak......so I assume that it's the 'safe' postion that the manfg is taking.
SeniorSitizen 12-02-2012 01:40 PM
On mine, after the stop valve, a T was put in the 3/8" line to the hot water side of the sink. The supply line to the ice maker comes off of the T with copper tubing and quickly transitions to 1/4" via a brass reducing compression coupling. Right or wrong it works and has for 30 years.
joecaption 12-02-2012 07:15 PM
Remove old shut off and install one of these.
http://www.amazon.com/dp/B007FMTCXW/...SIN=B007FMTCXW
TheEplumber 12-02-2012 08:13 PM
199 Attachment(s)
That's what I have done- but I found these are good too. They go on top of the existing stop
http://www.plumbingsupply.com/quick-tee-adapter.html
Huskyfan68 12-03-2012 08:44 AM
Thanks- I will replace it (not a fan.)- The cold water supply runs directly behind where the fridge is in the basement- Is there a way to install this angle valve directly into the cold water line? (I realize I will have to shut the water off)- but it's easier to tap in there (and closer) then to try to connect it to where the kitchen sink is
tylernt 12-03-2012 12:01 PM
1 Attachment(s)
Would this work? Get yourself a gate valve with compression fittings and an integrated drain. Cut the pipe behind the fridge (removing a short section) and install the gate valve to bridge the gap. Remove the drain cap and install an adapter fitting to go from the drain to whatever your icemaker needs.
