Ice Maker Hookup - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2013, 10:03 AM   #1
ice maker hookup
Hi, I am trying to hook up my refrigerator icemaker to the water supply line. It is a copper line that is coming out of the wall, it has some kind of fitting on the end that I am not familiar with.
Can anyone tell me how I should attached the supply line to the icemaker with this configuration?
Thanks!
Harlan
harlan07 is offline   Reply With Quote
Old 07-12-2013, 10:16 AM   #2
Rewards Points: 13,296
That is a mess.
No idea why they would have ran that big a line for just an ice maker.
It could have been done with one flared pipe cap.
Going to have to find the shut off (most likely under the sink)
Set a pan under it and remove those fittings and install a 1/4 turn shut off valve.
It would look a whole lot better with a real ice maker box.
http://www.bing.com/images/search?q=...ox&FORM=RESTAB
Old 07-12-2013, 10:21 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 452
What Joe said- plus you have a kink where the pipe comes out of the wall.
Using a small tubing cutter- you need to cut behind the kink and add the 1/4" stop valve
Ice maker will not eject ice BIG DIY'ER Appliances 3 07-16-2012 04:20 PM
250 Volt Hookup Question 451stroker Electrical 14 12-14-2011 07:12 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
