Ice Maker Connection - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2013, 12:13 PM   #1
Rewards Points: 81
I am adding a second refrigerator. The connection for water for the ice maker will be very close to where the original connection was made. I have attached a picture of the current fitting. Is there a fitting to make a tee out of this to go to the second fridge so I don't need to cut, solder, etc.? A link to the specific item at Lowes would be helpful.
OhioDon is offline   Reply With Quote
Old 11-14-2013, 12:28 PM   #2
Rewards Points: 13,450
http://www.homedepot.com/s/BrassCraf...2520MPT?NCNI-5
One of these, a short 1/2 nipple and 2, brass inserts that slip inside the valve will work.
Old 11-14-2013, 12:32 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 556
This link shows three way valves in the middle of the page and quick tees at the bottom. Your problem will be to find one with 2, 1/4" branches.
http://www.plumbingsupply.com/angle.html
Old 11-14-2013, 12:42 PM   #4
joed's Avatar
Rewards Points: 12,402
That is the same angle stop used under sinks or for toilet shut offs.
Personally I wouldn't use that plastic tubing in my house. We just had two of them in the office feeding the coffee machines split open do to age (about 6 years).
Old 11-14-2013, 12:46 PM   #5
Rewards Points: 81
Thanks to all. If I decide to stay with plastic tubing, could I use this? I found it on the plumbingsupply.com website.
Old 11-14-2013, 12:55 PM   #6
Rewards Points: 81
Lowes has this tee. Is this what I need?
Old 11-14-2013, 12:55 PM   #7
Rewards Points: 81
Is there a flexible tubing I can use? I'd rather not use copper so I don't have to be careful about kinking.... Such as PEX?
ice maker connection Huskyfan68 Appliances 2 12-10-2012 03:08 PM
ice maker water connection HHac8014 Plumbing 1 02-15-2010 09:33 PM
Telephone Jack Connection Problem jogan Electrical 9 04-20-2009 06:10 AM
Ice Maker Not Getting Water sgorak General DIY Discussions 3 10-27-2008 08:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-24-2008 11:14 PM
