Old 08-25-2009, 07:09 PM   #1
ice maker
my ice maker stoped making ice
Masrea is offline   Reply With Quote
Old 08-25-2009, 07:12 PM   #2
Moderator
Termite's Avatar
ice maker
That's a shame. Would you consider providing us with some information that we might be able to use in an effort to help you remedy the problem?
Start with:
  • Brand
  • Symptoms
  • Your experience level with plumbing
Old 08-25-2009, 07:13 PM   #3
ice maker
Originally Posted by Masrea View Post
my ice maker stopped making ice
it was working very good a few days ago ,, even the bar is down but no ice ,,but i find water leaking under the refrigerator
Old 08-25-2009, 07:18 PM   #4
Moderator
Termite's Avatar
ice maker
That's a start. You might want to take a look at the connection between the back of the fridge and the little tiny flexible waterline that comes up from the floor or out of the wall. There's a small nut on there. See if that's the source of the leak. Wherever the little waterline originates in your home, there should be a shutoff valve. Might be prudent to shut that off until you determine the source of the leak.
Was your fridge moved recently? For cleaning or anything?
Old 08-25-2009, 07:22 PM   #5
ice maker
NO i didn`t move it for the last 11 years,,it was working fine few days ago..
Old 08-25-2009, 07:24 PM   #6
Moderator
Termite's Avatar
ice maker
Well, now you have something to check on. That little connection I told you about.
Old 08-25-2009, 07:58 PM   #7
GC/Master Plumber/Mech
ice maker
Here's a little different approach
Do you know what the line to the ice maker is made of. If it is poly or plastic you might think of replacing it to copper.
Back to the ice make all ice makers are basically the same. Water come in through a supply line and to a water valve. Some ice makers have dual valves (Ice and water in the door). Locate the water valve and disconnect power. Remove the connector on the water valve and check the ohms across the two terminals. If you get nothing then the valve is bad if you get around 20 ohms then it's time to check the valve for restrictions. Even with alittle leak you should make ice.
Good luck brother
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-25-2009, 08:45 PM   #8
ice maker
I just had this same issue with my fridge. It was a leaking solenoid on the dual water inlet valve. I'm waiting for the replacement part to ship.
Open the access panel(s) behind the unit and have someone turn the water supply line on (assuming you've turned it off, which is a safe assumption if you've got a leak!). In my case, water started coming out of one of the water inlets, your leak may be in a different area.
mdos is offline   Reply With Quote
Ice Maker Not Getting Water sgorak General Discussion 3 10-27-2008 09:02 PM
Kenmore ice maker acting strange BJLower Appliances 3 10-25-2008 12:14 AM
Ice Maker problem. sflamedic Appliances 5 08-25-2008 06:28 AM
kitchenaid ICE MAKER not working??? elway Appliances 5 09-14-2007 10:27 AM
