Ice Machine - Air Gap Plumbing - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-12-2012, 02:22 PM   #1
Ice Machine - Air Gap plumbing
Ok, installing an ice machine in a cabinet spot. 24 inch, gravity drain. I realize this needs an air gap, and understand what this implies. This is on a first floor with a full basement (unfinished) under it.
My solution is to put a floor drain in, flush with the floor, below the ice machine drain. Under the drain, in the basement directly below, to put a p-trap and run 5 feet to the main drain line for my entire home (3.25OD at that point, obviously not running that big on the way there though)
Now, I know this is fine, my question comes to venting. This 5' run will not be vented. However, connected 12" away on that same 3.25OD is another 5' run that goes to a sink that IS vented. Is this fine? Will I have any troubles? And is that code?
valex is offline   Reply With Quote
Old 01-12-2012, 09:55 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 994
As you mentioned work fine it will, as for the code that all depends what code you are under, under our code you can run from a vented main, 10’ on a 3” line you cannot connect a non vented waste arm to an existing vented waste arm, if its a vented branch you should be fine,,if I understood your question correctly.
Also the floor drain and air gapped waste cannot be concealed, example ( inside a cabinet )
Good luck.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
plumbing a washing machine in basement Chris Chapple Plumbing 1 01-30-2011 12:18 PM
Plumbing: Relocating the washer machine!!!! powder room Plumbing 2 09-04-2010 02:01 PM
How do I remove the plumbing for a Washing Machine tdstyles Plumbing 4 07-17-2010 02:28 PM
Plumbing a Washing Machine Drain MikeWood Plumbing 2 01-21-2010 07:10 PM
Help Plumbing in Coffee Machine singforsupper Plumbing 2 08-19-2006 10:28 AM
