I Was Told Water Pressure Too High - Bunk Or Truth? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-23-2009, 03:18 AM   #1
Rewards Points: 1,016
I was told water pressure too high - bunk or truth?
A plumber told me the water pressure to the house was too high, and would cause damage to pipes and such. Said there is a water pressure regular at the street near the water meter - and it needs replacment.
Bunk or truth? If truth, what is involved in replacing the regulator?
thx!
Vince
Old 04-23-2009, 04:55 AM   #2
TRUTH....
water pressure should range between 60 and 80 psi. Any higher especially in excess of 100 can damage plumbimg and valves in appliances such as dishwasher, washing machine, ice maker, etc. See my blog about pressure here on the DIY BLOGS or on my blogsite which is listed on my profile.
As far as the pressure regulator I recommend you let your licensed plumber do the job.
faucetman886 is offline   Reply With Quote
Old 04-23-2009, 05:25 AM   #3
the Musigician
DangerMouse's Avatar
what he said....
it may be the city's responsibility or yours, depending on which side of the meter it's on, but it does need fixin'!
DM
Old 04-23-2009, 06:57 AM   #4
HVAC / Plumbing
you should have no more than 60 psi on/at the fixtures
kenmac is offline   Reply With Quote
Old 04-23-2009, 07:32 AM   #5
Anything over 80 lbs is high. Under 30 presents problems. Anything inbetween is "normal". The problems involved in replacing the regulator depend on the fittings used to install it. Your main water line is not something you want to have broken down for any length of time.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 04-23-2009, 08:01 AM   #6
This house & last it varied between 80-85
I have learned not to leave hoses turned on as they will burst from the pressure
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 03:01 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 05:10 AM
High pressure in water line atlfiveo Plumbing 5 02-06-2007 09:04 PM
Bad water pressure (well water) fnkyniedls Plumbing 2 10-22-2006 11:42 PM
