Old 06-18-2009, 07:43 AM   #1
I thought I put it back together properly: leaky shower valve (Matco-Norca)
No surprise - I'm an idiot.
This is the shower valve in question (Matco-Norca). I'm in a condo that was built 3 years ago, so the valve is "new"
This piece attaches to another piece which attaches to the metal pipes which gives my shower water.
I took it apart because I wasn't getting any shower output below a certain temperature. I put it back together and got my shower working at any temperature... But now it leaks between the red ring and the hub seat (I'm using this diagram - it's not the exact system but it looks the same to me).
This cartridge plugs into something else (see patent here) , which I have aligned, and plugs-in flush, although there's a gap (which is why I thought I needed to tighten hard. It's still leaky when assembled.
I got one of the two to work, with a drip every 5 minutes (tolerable).
I've tried magic putty, silicone, teflon tape, and I'm not sure what to do. I'm using lots of pressure to tighten, so much so that when I overtighten it it hard to turn the shower handle.
What makes it even funnier, is that I have a second shower in my condo with the exact system, I took that apart, and in putting it back together it too leaks between the red part and the hub. It makes me feel like I'm putting it together wrong.
All the seals look okay - no corrosion (when I touch them they look/feel in excellent condition).
Please help before I pay $500 in idiot taxes. Thanks.
shuuy is offline   Reply With Quote
Old 06-18-2009, 11:44 AM   #2
DIY'r
ScottR's Avatar
That's probably the #1 mistake made with this sort of thing -- over-tightening ruins washers/gaskets/o-rings, and as you discovered, causes parts to bind up.
Are you certain about the seal at the bottom of the cartridge (purple gasket pictured in your post)? My first guess is that when you tightened it down you damaged it. The damage may be on the back side of the gasket, so pop it out (gently) and check the back.
If every seal is really excellent, you may have cracked something in the cartridge, or there's a seal buried in there somewhere.
ScottR is offline   Reply With Quote
Leaky wobbly shower arm tima2381 Plumbing 15 06-22-2008 05:02 PM
Replacing shower valve - galvanized pipe? rjniles Plumbing 2 05-08-2008 10:29 PM
Shower Valve Destroyer ? Help! doneitnow Plumbing 2 05-05-2008 11:15 PM
Can't reinstall shower valve properly ptoneil Plumbing 3 04-10-2008 11:05 PM
How to change the shower valve? amdspitfire Plumbing 17 04-06-2008 10:05 PM
