I Think There Is A Hole In Cast Iron Pipe From Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-17-2012, 09:59 AM   #1
Angry
I think there is a hole in cast iron pipe from toilet
HELP HELP
I have a leak coming from that cast iron pipe coming from the second floor bathroom. Where should I start to look first for where there might be a leak. Do I start in the basement because it is dripping by a window. The toilet all of a sudden started to sound different. Like air in the line or something. How do you cut that cast iron?
cprice
cprice is offline   Reply With Quote
Old 09-17-2012, 10:02 AM   #2
Angry
i need some help, please.
Old 09-17-2012, 10:06 AM   #3
Rewards Points: 14,312
At some point all that old cast iron was bound to leak.
I would start by checking to see if the lines just plugged up and run a snake down it to clear it out.
Not sure how you could see it leaking by a window.
If it's leaking on the second floor why would you be looking for a leak in the basement?
You can rent a chain cut to cut it. Home Depot may have one for rent.
Old 09-17-2012, 11:57 AM   #4
have you seen the water dripping off of the pipe? pictures help a lot
Old 09-18-2012, 05:11 AM   #5
Rewards Points: 1,300
Realy need more info than this. Is this a first floor over a basement or is this a second floor over a finished ceiling? How do you know it is leaking from the pipe? Can you see where the leak is coming from? Any pictures of the area in question?
danpik is offline   Reply With Quote
Old 09-18-2012, 08:51 AM   #6
Plumber
TheEplumber's Avatar
Rewards Points: 914
I do too
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 01:42 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Galvaized pipe to cast iron main. rosemonster Plumbing 0 01-04-2011 12:49 AM
Repair of cast iron sewer pipe within concrete cando Plumbing 5 04-22-2009 11:10 PM
