Old 06-07-2009, 06:52 PM   #1
I think my bladder tank is shot
I have noticed the pump has been short cycling lately. I relieved the pressure of the water in the tank and checked the air pressure (0 psi).
I gave it a very small shot of air with my airtank and then checked the pressure and water came out. I think the bladder is ripped inside. What do you think? It is a well trol 120 I believe.
Plumbvoltage is offline   Reply With Quote
Old 06-07-2009, 08:38 PM   #2
how old is it?
sounds shot from what you described.
redline is offline   Reply With Quote
Old 06-07-2009, 09:28 PM   #3
Originally Posted by redline View Post
how old is it?
At least 10 yrs, no more than 15.
Old 06-07-2009, 09:33 PM   #4
GC/Master Plumber/Mech
You shouldn't get water from the valve stem. I'd replace it
Old 06-07-2009, 09:34 PM   #5
If you got water out the air valve the bladder is shot, time for a new tank. When you install a new one check the pressure first and add or remove air until pressure is 2 lbs less than pump turn on pressure.
hayewe farm is offline   Reply With Quote
Old 06-07-2009, 09:37 PM   #6
Yeah water came out. Looks like its off to the supply house for a new one.
Thanks.
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Nightmare water tank job Marvin Gardens Plumbing 6 11-04-2008 12:09 PM
No water pressure in my pressure tank GordH Plumbing 6 05-18-2008 12:19 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
