I Think I Put A Lag Screw Into A Vent Pipe. - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-06-2012, 08:19 AM   #1
Rewards Points: 590
I think I put a lag screw into a vent pipe.
My wife said the bathroom smells like poop. Sure, enough it did. You could smell a slight sewer smell from an area where I removed a baseboard to install a cabinet. Then I got to to thinking, "did I screw that left lag bolt into the vent pipe?" Well, I think I did, because up in the attic, the vent pipe comes out of the 2 x 4 header about 10" away from where I screwed it in. I am guessing the vent pipe angles up the wall to move around a larger support beam. When I unscrewed the screw, it didn't have a pine smell on the end of it like the other screw.
How can I best fix this blunder?
Plumbers epoxy? I also read that you can screw in a stainless screw with silicone on it, but I'm kind of leaning towards not doing this.... This is a good size screw, about 3/8 in diameter.
Thanks for any help.
noone is offline   Reply With Quote
Old 01-06-2012, 08:23 AM   #2
Lightfoot's Avatar
Rewards Points: 272
I'd probably use some epoxy such as JB weld or similar, scuffing the surface of the pipe with some coarse sandpaper to make sure to get a good bonding, and making the repair bigger than the hole.
Lightfoot is offline   Reply With Quote
Old 01-06-2012, 08:23 AM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by noone View Post
How can I best fix this blunder? Plumbers epoxy? .
After the work needed to get access to the pipe so you can really check it...
the best fix option will depend on the material.
Is the vent pipe Cast, Steel or PVC?
The Following User Says Thank You to TarheelTerp For This Useful Post:
plummen (01-07-2012)
Old 01-06-2012, 09:18 AM   #4
Rewards Points: 590
It is PVC.
I was planning on cutting out a 4" x 4" piece of drywall and go from there.
Old 01-06-2012, 09:40 AM   #5
Rewards Points: 13,740
One sure way to seal it would be to take a short piece of 4" PVC about 4"" long, cut it cross ways so a 1/3 section is left, apply primer and glue and stick it over the hole.
Another short Stainless steel lag with silicone on it may or may not work, The pipe is round and the back side of the lag is not.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
More Power! (01-06-2012), TarheelTerp (01-06-2012)
Old 01-06-2012, 09:50 AM   #6
Rewards Points: 590
I hear JB Weld is solid as a rock.
Using this seems more than sufficient, I would think.
Old 01-06-2012, 10:01 AM   #7
jproffer's Avatar
Rewards Points: 714
It is PVC.
Isn't JB weld just for metal??
I'm really asking, not trying to be a smart-a$$ ....that's unlike me to NOT be a smart-a$$, but I have my moments.
jproffer is offline   Reply With Quote
Old 01-06-2012, 10:58 AM   #8
Rewards Points: 340
I like this method, but use a large pipe clamp or two instead of screws - the screws may catch "stuff" -
tribe_fan is offline   Reply With Quote
Old 01-06-2012, 11:19 AM   #9
jproffer's Avatar
Rewards Points: 714
Not sure, but I think this part of his answer was referring to the OP's idea in the 1st post.
I also would go with hose clamps vs. screws if it was me.
Old 01-06-2012, 11:41 AM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 682
No screws needed. Just glue the patch as joe said. The glue will hold it
Sent from my DROID2 using DIY Chatroom
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (01-06-2012)
Old 01-06-2012, 11:49 AM   #11
Rewards Points: 590
Their website specifically lists PVC as an application. Seems like this hard and strong epoxy would work perfectly in this case. After all, the vent pipe is only holding gases!
http://jbweld.net/products/jbweld.php
Old 01-06-2012, 02:03 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
Was the screw removed? If not, and it's just a vent pipe.....then the screw is sealing the hole unless the pipe cracked. I would not expect any smell to come out unless the screw was removed.
You might have something else wrong.
ddawg16 is online now   Reply With Quote
Old 01-06-2012, 02:44 PM   #13
Rewards Points: 590
Oh great. I was wondering how that could cause an issue. I hope it's not cracked. I guess I will be able to tell once in there if it was indeed a vent pipe I went into.
The only other things that changed in this bathroom remodel were
1. New toilet installed. Not sure how I could have screwed this up since it is caulked in good and of course a new wax seal that came with the Kohler toilet was used.
2. About 2.5 feet of baseboard was removed so that the new vanity would sit flush with the wall. So behind the vanity's legs the concrete slab is exposed beneath the end of the drywall. There is obviously a drain pipe in this area also where the hot and cold supply valves are located.
I guess it's possible that there was some kind of leak before hand. I can't feel any moisture where the exposed slab is at all.
The smell is not super bad, it seems like it comes and goes and is not totally repulsive. The few times I had noticed it, I figured I was smelling someone's residual poop smells.
Thoughts?
What else could be wrong? Could it be a busted sewer pipe in the slab? Wouldn't that be pretty obvious?
An inspection of the vent pipe in the attic yields no odor as far as I can tell.
Old 01-06-2012, 03:03 PM   #14
Missouri Bound's Avatar
You caulked in a toilet?...hmmm. I was told to never caulk a toilet.
Old 01-06-2012, 03:06 PM   #15
Rewards Points: 590
Yes, of course I caulked the bottom of the toilet. We set it and then caulked the bottom to the tile.
Standard practice I thought, at least in the 3 houses I have lived in and 100's of other people's houses I have been in.
**edit** I just read that you should leave a small area uncaulked around the back just in case of a leak. I will remove some of the caulk from the back tonight.
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 06:52 PM
Vent Pipe Stink in house zacker Plumbing 30 12-13-2010 12:19 PM
Water leaking from vent pipe die_of_ennui Plumbing 3 03-25-2010 08:11 AM
Bubbling in toilet rballard Plumbing 11 08-30-2008 07:15 PM
