Old 07-14-2009, 05:47 PM   #1
I still hear water running when I shut off the main water shut off valve
Help! A person from the water company stopped by and said there was a high usage of water in the area. He asked if we had a water leak, a leaky toilet, or sink. We didn't think so. Nothing drips and the water in the toilet always looks to be at the same level and doesn't just run. We received a bill for last month and it was $750.00 We used like something of 100 million gallons.... and this month is $450.00 We didn't even live here most of the time last month. So basically we turned the water off, by the main shut off valve, but we still hear water running through it. If we open it back up it flows really fast. Would there be water still running through it if we shut it off, and should I hear the water all the time if its open? Where would this problem be coming from? Does it sound like its our problem or the counties?
Thank you
jnut is offline   Reply With Quote
Old 07-14-2009, 06:20 PM   #2
It was a dark and stormy
Yoyizit's Avatar
The sound from a leak upstream of your shutoff valve is being transmitted through your pipes. Turn off everything in the house and see how fast the meter turns. We were losing a gallon in 3 minutes into the earth.
Normal usage is 100 gals per person per day.
Old 07-14-2009, 06:26 PM   #3
What was the cost of the repair of your leak? Where was is coming from?
Old 07-14-2009, 06:30 PM   #4
Xtreme DIY'r
My main water valve was sticking & had to be replaced
It would not fully shut off the water
Where is your water meter?
Where does the pipe go after the water meter?
Does it go into a concrete slab?
If you are being charged for the water then the leak is after the meter
Here anything after the meter is the homeowners responsibilty
But they should have know from prior useage that the problem was with your house
Old 07-14-2009, 07:36 PM   #5
Yoyizit's Avatar
Originally Posted by jnut View Post
What was the cost of the repair of your leak? Hundreds. They ran a new line and bypassed the old line.
A pinhole leak in a pipe that ran through the earth under the slab that our house rests on.
The WaCo (Water Company?) added orthosphosphate to the water to prevent this.
For a while pinhole leaks in this area were rampant.
Old 07-15-2009, 08:01 AM   #6
General Contractor
It's not uncommon for the main shut off in the house to be faulty or stick. As far as who is responsible if the leak is outside, that seems to depend on where you live. Here in Virginia the county is responsible if the leak is from the meter back to the water main. If it is after the meter (including the service) the property owner is responsible for the repair.
If you are losing the amount of water you say you are and the leak is outside, you should be able to find the leak by looking for wet soil or bubbling of water through the soil. It should be a 1" pipe, flexible ABS is typical in my area. You can put a neoprene leak repair clamp (nipple) on it to fix it yourself.
ARI001 is offline   Reply With Quote
Old 07-15-2009, 08:46 AM   #7
Household Handyman
Finding pinhole leaks in poybutylene (a type of plastic) AND some copper piping that are water supplies from water meters to homes is very typical. The amounts of usage you have stated should have shown up like an oil geyser in Texas though. I know you've done testing, but do one more: See if you have a cut-off valve immediately after the water meter, the homeowner's side. IF SO, see if you can close this valve and feel confident that you have closed it. Make sure all other faucets within the home are closed. Now, make sure to close the stop valves on each toilet, if you can, this is a place where you may have a leak and let's temporarily eliminate it. open the closest outside faucet, let it run until it stops, or tries to stop. At this point you should be able to see two things: 1) If the meter is running at all whether it is the older analog (dials) type or the numerical type, water moving will move either one hand of the dials type or the rightmost number of the numerical type. 2) Watch the outside faucet, if there is water moving through the meter there will be water coming out of the faucet, water pressure no matter how small will move wate, provided all faucets/valves in the house are closed. This can be a tedious process but will work. Now-if you see the meter moving at all, and there is no water coming out of the faucet, chances are you have an undergroung leak between the meter and the home. IF SO, you should will have to find or imagine where the water line comes into the house, and look for a very wet spot in your lawn. As I stated, this is a tedious process but will work and I hope this will help you, David
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
dripping from water shut off valve underneath the toilet maitri Plumbing 4 12-10-2006 04:58 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
