I Need To Know How To Remove The Front Of A Cultured Marble Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-05-2010, 12:22 AM   #1
I need to know how to remove the front of a cultured marble tub
My wife bought a new faucet for our tub, it is cultured marble, and it looks like you just cut the caulk line and pry it off.... is that right? I sure would hate to break it. can someone give me some advice???? Thanks!
hall.jacob is offline   Reply With Quote
Old 03-05-2010, 07:22 AM   #2
The only type tubs I know of with removable panels are jacuzzi types. Don't go slicing up a tub to replace a faucet, there is usually other access for that. A pic would help us.
Old 03-05-2010, 09:30 AM   #3
Rewards Points: 352
are you talking about just the tub spout, prying on the plumbing without knowing for sure what you are prying sounds like a recipe fo disaster.
you are going to have to give more info it sounds like you have a cultured marble faucet
are you going to pry off the old faucet or the tub itself
plumberinlaw is offline   Reply With Quote
Old 03-05-2010, 10:04 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
He's talking about the 'skirt' for the tub.
I don't install or usually am not even around when someone else installs that stuff. Usually they do leave an access especially if there's a pump on it, but generally the access is on the pump end, not the faucet end. The other option is access from beneath if you have it, but even that can be a pain, and risk damaging the tub when cutting an access in the subfloor.
Journeyman Plumber
Old 03-05-2010, 10:17 AM   #5
Rewards Points: 352
I did not see enough info to determine if it is a whirlpool tub or if there is a skirt or access panel. I will just wait until the OP leaves more information, more will be revealed
Old 03-05-2010, 10:35 PM   #6
Doing it myself
Alan's Avatar
Based on his thread title, it sounded to me like he's trying to remove a 'skirt'
Journeyman Plumber
Old 03-06-2010, 10:53 PM   #7
Barry
What I've seen done to remove the front panel, is to remove all the caulk around the edges to break the seal, then pull on it with a couple of suction cups or plungers to pull it out. Be real careful though, they do break easily.
Tub Refinisher is offline   Reply With Quote
Old 09-12-2010, 07:26 PM   #8
i have a similar issue. there are 4 decorative screws on the face of the skirt. when they are removed the skirt is still fairly tight. if i try to pry it off i can see the skirt (18" x 48") bowing in the center. the ends however, remain fixed. since i need to get access to it, is the plunger method the only way?
hassenpheffer is offline   Reply With Quote
Old 09-12-2010, 10:23 PM   #9
Rewards Points: 352
this post is 6 months old why not start a new thread
Tags
cultured marble removal
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 02:20 PM
Trimming/sanding cultured marble - bathroom vanity top SpookyLugBolt Kitchen & Bath Remodeling 3 02-02-2010 10:24 PM
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Front Door - Door stops? 1655graff Carpentry 6 08-14-2009 01:40 PM
Ceramic or Porcelain for Front Room/Living room (advice needed) irishgem@ymail. Flooring 4 07-08-2009 02:46 PM
