I Need Helping Repairing This Floor Drain! - Plumbing - DIY Home Improvement | DIYChatroom
Like Tree3Likes
  • 1 Post By MTN REMODEL LLC
  • 1 Post By BlackTiger
  • 1 Post By RRH
Old 01-02-2017, 12:11 PM   #1
Rewards Points: 219
I need helping repairing this floor drain!
We have a floor drain in our utility/laundry room. Over the years, the screen or grille over it has came off and been lost. My wife is wanting to put down peel and stick tile in here and wants the drain fixed. This is a very commonly used entrance into the house by visitors so she is wanting to make the room look better.
Looking at it, it looks like the screws holding the cover on broke. I have looked all over and cannot find one the same size. I have half a mind just to level off the imperfections in the concrete and somehow epoxy a larger screen over the hole.
I have no idea what options I have here so I am asking here for help...What can I do to fix this and get it ready for her to tile?
bassadict69 is offline   Reply With Quote
Old 01-02-2017, 12:20 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,390
Re: I need helping repairing this floor drain!
Sort of similar... and if you can not find a grill that would fit those screws (they are probably brass and a screw extractor could likely remove them)...
I've several times been able to find the black plastic grills at a big box that I could cut/fashion to fit and screw down with small tapcons, or overlay if your flooring/covering material will be as thick.
bassadict69 likes this.
MTN REMODEL LLC is online now   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
bassadict69 (01-03-2017)
Old 01-03-2017, 07:06 PM   #3
Rewards Points: 288
I found this website that has a wide variety of sizes available. I can't speak to their quality or anything but maybe they've got the one to fit.
https://www.plumbingsupply.com/repla...in-covers.html
BlackTiger is offline   Reply With Quote
The Following User Says Thank You to BlackTiger For This Useful Post:
Old 01-03-2017, 08:19 PM   #4
Rewards Points: 219
Thank you!
Old 01-03-2017, 08:55 PM   #5
RRH
Rewards Points: 322
Also just a note
Most people forget to pour some water in there every 6 months or so to stop the sewer gas from coming up. Otherwise the p trap dries out. A little oil also makes it last longer.
RRH is offline   Reply With Quote
The Following User Says Thank You to RRH For This Useful Post:
bassadict69 (01-04-2017)
Old 01-04-2017, 07:47 PM   #6
Rewards Points: 219
Can't say I have ever put water down this drain unless cleaning up a leak from water heater, washing machine, etc. Thanks for this info!
Repairing hole in vinyl siding nickuf Roofing/Siding 3 08-19-2013 10:56 AM
Repairing a few leaks on start collar - Foil Tape or Mastic? Hogan773 HVAC 7 08-25-2012 09:55 AM
Repairing plaster ceiling 3'x5' hole stock2mal Drywall & Plaster 0 01-27-2012 06:14 PM
repairing electrical outlets in old Plaster lath walls jjchips Carpentry 3 09-04-2010 10:20 PM
A Midwesterner that grew up helping others with projects BJLower Introductions 1 08-02-2008 09:42 AM
