Originally Posted by jagans
Can you live with what you have till spring? Everything works better when its a little warmer, glue, fingers, etc.
i wish but it keeps freezing and i cant do dishes or use my dishwasher!!! so its becoming a pain
its mainly just the one pipe heading from the kitchen to the main supply right there is freezing in that outside area
i added heat tape and this is not a solution to the problem
currently i had to cut the pipe under the crawl space and add a 5 gallon bucket to the mix lol
the big issue is they didn't slope it at all so the build up over time because of the garbage disposal is making the water just hang out in the line causing it to freeze
