I Need Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-12-2008, 11:42 PM   #1
I need help
how to run a waterline from the refrig to the hotwater heater
elise johnson is offline   Reply With Quote
Old 06-13-2008, 06:05 AM   #2
Rewards Points: 156
hmm
I'm not sure why you would want to do this. Do you mean running a cold water line to your icemaker?
jayp is offline   Reply With Quote
Old 06-13-2008, 07:46 AM   #3
Registered User
Termite's Avatar
JayP's right. There shouldn't be any reason to run hot water to the fridge.
If you're installing an icemaker line, you need to tell us what kind of water supply piping your house has. You'll tap into a cold line for this purpose, not a hot.
If you have 1/2" copper, most home centers sell kits with everything you need to install a line. This kit will include a saddle valve that pierces the copper line (very easy), tubing, and all the connectors you'll need. If you have another type of plumbing don't panic, we'll talk you through it.
Old 06-14-2008, 09:21 AM   #4
Maybe through this, you can get an information regarding your problem: http://www.askmehelpdesk.com/plumbin...ine-25977.html
jpiers is offline   Reply With Quote
