I Need To Get This Rolling And Finish It!! - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2012, 09:55 AM   #1
Rewards Points: 335
I need to get this rolling and finish it!!
below, you will see a link to the original thread (page 2) in which i had questions about my MOEN shower control.
the plastic cover that you see in the picture, how do i remove this without damagaing anything behind it as well as the fiberglass walls of the bath tub?
I am still having problems getting that plastic collar out and I was in hopes that if I remove that plastic cover, I can see whats going on behind it (I hope).
also, what are the chances that this cartridge would stop the screw on the left from working? The screw turns the way it should but I have NO WATER coming out when I open that screw up.
replacing shower cartridge
crankbait09 is offline   Reply With Quote
Old 07-17-2012, 03:03 PM   #2
Rewards Points: 335
, please tell me i don't need to contact a plumber
Old 07-17-2012, 08:15 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 450
Oh' mike has given you further directions at your other thread for removing the cartridge-
Removing the plastic cover will do you no good. Its actually a rough in/mud ring to gauge the size of the hole for the valve and trim plate. Some people use it to secure the valve in the wall-which may be your case.
As for the shut off screws, they are 1/4 turn. The slot should be at a right angle to the pipe to be off- only need to go 1/4 turn.
The Following User Says Thank You to TheEplumber For This Useful Post:
crankbait09 (07-17-2012)
Procedure and what paint, in painting oak cabinets smooth tommyncal Painting 11 09-29-2012 12:49 PM
tales of woe suffering and the tribulations of smooth walls drcristoff Painting 13 05-08-2012 10:13 AM
Rolling paint Sam Flores Painting 10 02-26-2011 06:32 PM
Spraying VS Rolling gdoucette Painting 5 06-18-2010 06:38 PM
