I Need Cast Iron To Pvc Help - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-23-2012, 03:53 PM   #1
I Need Cast Iron to Pvc Help
I am going to replace the old cast iron sewer stack in my basement to Pvc but need some help. There will be a sink in front of the stack and I want to add a drain line for the washer which is to the right . The main line down is 2" then goes to 4" which then goes into the floor. I want to cut it where I marked with the red lines and rebuild from there. Should I stack 2 tees near the bottom for the sink and washer drains? Or is there a better way of doing this? Also, do i need to have a vent coming off like the 2nd pic? The line goes up through the kitchen wall, tees to the kitchen sink, then up and vents out of the roof.
[IMG][/IMG]
[IMG][/IMG]
I've always thought this one was odd, there is a pipe leading away from this that turns up to the kitchen floor where there is nothing above. It is just laying there disconnected.
Any input is appreciated!
short1 is offline   Reply With Quote
Old 08-23-2012, 11:18 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
depending on your code, you will need to branch the new connections and re vent them.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 08-23-2012, 11:59 PM   #3
There was already a sink there, I guess I'm just adding a drain for the washer. The washer was draining into the sink. Im about to start framing everything in soon and have gotten rid of the cement sink to replace with a nice sink/cabinet setup, and installing a washer outlet box. Im in southeast wisconsin, does anyone know code for this area?
Bathtub Recommendations - Cast Iron or other? HandyFrank Plumbing 5 10-25-2011 04:25 PM
Help me! Cast Iron Leak (Picture) meandiet Plumbing 8 08-14-2011 05:41 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 07:38 AM
working with cast iron ericadami Plumbing 9 11-30-2008 01:45 PM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 11:07 AM
