I Need To Bend A 1/8" Copper Pipe-how? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-07-2011, 01:05 AM   #1
Rewards Points: 91
I need to bend a 1/8" copper pipe-how?
I need to bend 1/8" copper pipe. I think I would prefer one of those spring type benders that you insert the tube into. Where can I buy one?
Is there an easier way?
sofasurfer is offline   Reply With Quote
Old 08-07-2011, 01:18 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
if you want to make a really nice looking bend, then using a bender is the best way to do it.
Otherwise you can just do it carefully with your hands. Don't kink it.
Journeyman Plumber
Old 08-07-2011, 01:22 AM   #3
Rewards Points: 91
The project isn't worth the money for a bender. I tried it by hand and it kinks. I just remembered to check harbor freights site...I always forget about them...they have a 5 piece spring set for $1.99. Can't beat that any way
Old 08-07-2011, 06:09 AM   #4
DIY staff
Rewards Points: 7,174
Auto parts stores are a good place to get most benders.
Old 08-07-2011, 09:14 AM   #5
NACE Coating Inspector
mustangmike3789's Avatar
they may even have a loaner tool for free.
mustangmike3789 is offline   Reply With Quote
Old 08-07-2011, 09:28 AM   #6
Just call me Andrew
Rewards Points: 1,020
What is this for? Can you not use a braided stainless steel supply hose instead?
Andrew
secutanudu is offline   Reply With Quote
Old 08-07-2011, 11:57 AM   #7
biggles's Avatar
your talking soft copper if you have a lenght of wire that you can insert fill up the "inside" the 1/8 copper and bend it.....go slow hand over hand
Old 08-07-2011, 12:05 PM   #8
Rewards Points: 558
You can use a external spring which are for smaller diameter copper piping ( from 6 to 10 mm external diameter). Again they are made from flattered steel but with a 'funnel' at each end so that the copper pipe can be fed through the centre of the spring. With the spring surrounding the pipe, the spring prevents the wall of the pipe from spreading outwards as it is bent. As with the external springs, each pipe size requires its own specific spring.
epson is offline   Reply With Quote
Internal copper pipe cleaning handyless man Plumbing 2 06-22-2011 07:52 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 10:16 PM
copper pipe vs pex I'm in trouble Plumbing 4 06-28-2010 12:42 AM
can you bury copper pipe ? amakarevic Plumbing 12 08-05-2009 07:25 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 05:02 PM
