I May Be Forced Into Using The Sharkbite Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-04-2013, 03:02 PM   #1
Lord of Slums
Rewards Points: 1,974
I may be forced into using the sharkbite fitting
Bad gate valve. The gate valve shuts the water off to a trickle. I want to cut in a ball valve but the only real place to do it is right above the meter. Problem with sharkbite ball valves is they pinch if not strapped properly. I laid the job out already, cut out section of pipe, mount some bell housing clamps into concrete, pop on the sb valve then sweet in a section of pipe, done. What I am asking is can I just use a 3/4 inch compression ball valve? It would save me some trouble of having to drill into concrete.
mj12 is offline   Reply With Quote
Old 04-04-2013, 03:09 PM   #2
DIY staff
Rewards Points: 7,174
3/4 compression ball valve will work-----
There is a cool tool called a Jetswet---the will allow you you sweat a valve on with water in the pipe---I'll see if I can find a picture----
Old 04-04-2013, 03:11 PM   #3
DIY staff
Old 04-04-2013, 03:12 PM   #4
DIY staff
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (04-04-2013), TheEplumber (04-04-2013)
Old 04-04-2013, 09:15 PM   #5
Lord of Slums
Genius. It is worth ordering a whole kit of those. I have never seen one of these before. Amazing
Old 04-05-2013, 06:39 AM   #6
DIY staff
Those saved me from a nightmare---a basement water proofer hit the one inch main under the slab--
17 inches of snow made finding the Buffalo box unlikely-----so out came the JetSwet----and work continued. (After I changed my wet shirt)
Old 04-06-2013, 07:36 AM   #7
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Jet sweats are lifesavers! Whoever invented them has a special place in heaven.
JDC is offline   Reply With Quote
Old 04-06-2013, 09:11 AM   #8
Roofmaster
Rewards Points: 2,210
Yeah, and a special account at the bank too. Why the hell didn't I think of that one?
Old 04-06-2013, 10:03 AM   #9
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I love them. I have a 1/2 - 1" kit in my truck for service work.
We have one that goes through 2" ( I believe maybe 1-1/2) at the shop.
+1 for jet swet.
Journeyman Plumber
HELP - Broken Sink Trap Fitting NIGHTMARE! Steve Sr Plumbing 17 03-10-2013 05:45 PM
Sharkbite fitting at slight angle joebanks Plumbing 4 11-05-2012 10:35 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
