-   -   I may be forced into using the sharkbite fitting (http://www.diychatroom.com/f7/i-may-forced-into-using-sharkbite-fitting-176302/)
mj12 04-04-2013 03:02 PM
Bad gate valve. The gate valve shuts the water off to a trickle. I want to cut in a ball valve but the only real place to do it is right above the meter. Problem with sharkbite ball valves is they pinch if not strapped properly. I laid the job out already, cut out section of pipe, mount some bell housing clamps into concrete, pop on the sb valve then sweet in a section of pipe, done. What I am asking is can I just use a 3/4 inch compression ball valve? It would save me some trouble of having to drill into concrete.
oh'mike 04-04-2013 03:09 PM
3/4 compression ball valve will work-----
There is a cool tool called a Jetswet---the will allow you you sweat a valve on with water in the pipe---I'll see if I can find a picture----
oh'mike 04-04-2013 03:11 PM
https://encrypted-tbn0.gstatic.com/i...HJ-lftVHXhMlfw
oh'mike 04-04-2013 03:12 PM
https://encrypted-tbn2.gstatic.com/i...DaN-qTGrPomoy-
mj12 04-04-2013 09:15 PM
Genius. It is worth ordering a whole kit of those. I have never seen one of these before. Amazing
oh'mike 04-05-2013 06:39 AM
Those saved me from a nightmare---a basement water proofer hit the one inch main under the slab--
17 inches of snow made finding the Buffalo box unlikely-----so out came the JetSwet----and work continued. (After I changed my wet shirt)
JDC 04-06-2013 07:36 AM
Jet sweats are lifesavers! Whoever invented them has a special place in heaven. :thumbup:
jagans 04-06-2013 09:11 AM
Yeah, and a special account at the bank too. Why the hell didn't I think of that one? :huh:
Alan 04-06-2013 10:03 AM
I love them. I have a 1/2 - 1" kit in my truck for service work.
We have one that goes through 2" ( I believe maybe 1-1/2) at the shop.
+1 for jet swet.
