I Made A Lil Boo Boo.... - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-25-2013, 09:44 AM   #1
Rewards Points: 140
... what can i do to fix it ?
see the clean out. when i was roughing it, it looked to be sticking out enough.
but nooooooo :slap head:
the plug is glued in.
is there a screw in extension i could get ?
oooops
Last edited by beenthere; 08-25-2013 at 10:38 AM. Reason: So pic and description are in 1 post
Fix'n it is offline   Reply With Quote
Old 08-25-2013, 10:07 AM   #2
Rewards Points: 12,802
Why not just add an access panel in the drywall to cover it up?
Old 08-25-2013, 10:18 AM   #3
Bill Kearney
Rewards Points: 1,174
Ya gotta weigh the work required to figure out a way around it versus cutting pipe and rebuilding it properly. When you've got a wall open like this I'd say the latter is a much better idea...
wkearney99 is offline   Reply With Quote
Old 08-25-2013, 10:32 AM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 798
Ya know, I have 'never' made that mistake....nope, not me......
And, yes, they do make male screw in pieces....but PVC is cheap...I think I would cut...and glue on a longer piece and then cut that 'after' the drywall is up.
ddawg16 is online now   Reply With Quote
Old 08-25-2013, 10:38 AM   #5
Rewards Points: 140
ok, when you guys say to fix it. are you saying to cut out the wye. or cut out the just the threaded part of the wye ? and fix from there
Old 08-25-2013, 10:40 AM   #6
Rewards Points: 140
yeah, that is on the "plan" list. the issues isn't the drywall. it does stick out about flush with the DW. its the cabinet that will be the issue. i would like to have it out far enough, so that in the event of using it, a pan can be placed under it.
Old 08-25-2013, 10:41 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 798
if you glued the threaded coupling straight into the wye....then I would just pull the cap...and screw in a male threaded coupling....and if it's long enough....glue another female into the male end....
I believe they call that a threesome....
Old 08-25-2013, 11:34 AM   #8
Rewards Points: 446
Cut out the wye, glue in a new one with enough extension to get you the room for a pan and finish it out with the screwed clean out. Do not glue in the threaded plug, if that's what you meant before. It's threaded for a reason.
You'll probably need at least one slip/repair coupling if not two to replace the wye, depends on how much movement there is on the pipe the wye is in.
old_squid is offline   Reply With Quote
Old 08-25-2013, 02:12 PM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 348
Use a clean out cover plate and leave it as it is.
If your sink ever backs up- you'll probably pull and drain from the trap first, then cable through the 90. Those clean outs on the arm are hardly ever used
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
ben's plumbing (08-26-2013), oh'mike (08-25-2013)
Old 08-25-2013, 02:40 PM   #10
Rewards Points: 582
yep yep do what he says ..my guess is you will never use that clean out....no no never never ugh ugh ugh ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 08-25-2013, 09:13 PM   #11
Rewards Points: 140
yeah, i know it will most likely never be used. but i was there, and it was easy.
now. if i HAD NOT put the clean out in there, that B!tch would be clogggin up all the time.
Old 08-28-2013, 11:25 AM   #12
Rewards Points: 131
Instead of an access panel I usually put up a (fake) wall vent. It looks functional but is easy to remove if you need to get to the cleanout.
HitLines is offline   Reply With Quote
Any guidelines as far as how big, how many, or where the holes can be made in wall ? chrishallowell Building & Construction 3 09-03-2010 10:01 AM
Concrete Contractor and Masonry Contractor made a huge mistake homeowner12 Building & Construction 19 07-07-2010 10:37 PM
So WHY is this car not made NOW ?? 100 mpg, 135mph Scuba_Dave Off Topic 6 04-27-2010 04:16 PM
Made in USA ??????? Giles General DIY Discussions 12 04-17-2010 02:21 PM
Wire tracing tool made from old phone sthdbike Electrical 12 12-07-2009 12:41 AM
