-   -   i made a lil boo boo.... (http://www.diychatroom.com/f7/i-made-lil-boo-boo-185883/)
Fix'n it 08-25-2013 08:44 AM
1 Attachment(s)
... what can i do to fix it ?
see the clean out. when i was roughing it, it looked to be sticking out enough.
but nooooooo :slap head:
the plug is glued in.
is there a screw in extension i could get ?
oooops
joecaption 08-25-2013 09:07 AM
Why not just add an access panel in the drywall to cover it up?
wkearney99 08-25-2013 09:18 AM
Ya gotta weigh the work required to figure out a way around it versus cutting pipe and rebuilding it properly. When you've got a wall open like this I'd say the latter is a much better idea...
ddawg16 08-25-2013 09:32 AM
Ya know, I have 'never' made that mistake....nope, not me......:whistling2:
And, yes, they do make male screw in pieces....but PVC is cheap...I think I would cut...and glue on a longer piece and then cut that 'after' the drywall is up.
Fix'n it 08-25-2013 09:38 AM
:laughing:
ok, when you guys say to fix it. are you saying to cut out the wye. or cut out the just the threaded part of the wye ? and fix from there
Fix'n it 08-25-2013 09:40 AM
yeah, that is on the "plan" list. the issues isn't the drywall. it does stick out about flush with the DW. its the cabinet that will be the issue. i would like to have it out far enough, so that in the event of using it, a pan can be placed under it.
ddawg16 08-25-2013 09:41 AM
if you glued the threaded coupling straight into the wye....then I would just pull the cap...and screw in a male threaded coupling....and if it's long enough....glue another female into the male end....
I believe they call that a threesome....
old_squid 08-25-2013 10:34 AM
Cut out the wye, glue in a new one with enough extension to get you the room for a pan and finish it out with the screwed clean out. Do not glue in the threaded plug, if that's what you meant before. It's threaded for a reason.
You'll probably need at least one slip/repair coupling if not two to replace the wye, depends on how much movement there is on the pipe the wye is in.
TheEplumber 08-25-2013 01:12 PM
199 Attachment(s)
Use a clean out cover plate and leave it as it is.
If your sink ever backs up- you'll probably pull and drain from the trap first, then cable through the 90. Those clean outs on the arm are hardly ever used
ben's plumbing 08-25-2013 01:40 PM
yep yep do what he says ..my guess is you will never use that clean out....no no never never ugh ugh ugh:laughing::laughing::laughing: ben sr
Fix'n it 08-25-2013 08:13 PM
yeah, i know it will most likely never be used. but i was there, and it was easy.
now. if i HAD NOT put the clean out in there, that B!tch would be clogggin up all the time.
HitLines 08-28-2013 10:25 AM
Instead of an access panel I usually put up a (fake) wall vent. It looks functional but is easy to remove if you need to get to the cleanout.
http://i.imgur.com/t1UBUHZ.jpg
