**I Just Installed My RHEEM ECO-SENSE 180DVN3 Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-22-2012, 08:55 AM   #16
Master Plumber
Javiles's Avatar
Rewards Points: 994
Hope you did-int use any of the galvanize from home depot ??
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 12-22-2012, 09:43 AM   #17
Rewards Points: 3,130
Originally Posted by stephenbbb View Post
Guys,
Do you have gas fitters licenses? I just got a letter from Rheem that in order to honor the warranty i have to prove to them I have followed all local code for the install...
If it passed inspection, it must have been installed to code. Where I live, as long as it passes, they don't care who did the work. A homeowner can do everything for a house but well and septic.
Old 01-02-2013, 08:32 AM   #18
Maintenance
My neighbor is an inspector for commercial tankless and he says return it. They break down a lot, need expensive maintenance every year (flushing) and after 2 years the model is no longer in production and there are no parts.
I also noticed Rheem does not have a 800 number for customers.
Any comments?
stephenbbb is offline   Reply With Quote
Old 01-02-2013, 10:46 AM   #19
Any comments?
Well, my Rheem has not broken down in the four years we've had it. And the manual for mine says nothing about flushing the unit, so I have not done so. What would ever accumulate in a tankless unit that would require flushing?? I know there are issues with tankless units if you have hard water, but I do not.
Old 01-03-2013, 09:21 AM   #20
Rewards Points: 91
I have a Tagaki (sp) that has been going strong for 9+ years with not one single problem. It is gas fired.
George6488 is offline   Reply With Quote
Old 01-03-2013, 11:31 AM   #21
If anyone is interested in elec I installed about 3 months ago, a steibel eltron tempura 24 plus.
It rocks. German made, unlike most other Tankless it has a regulating valve that limits flow to make temperature so your water temp is always rock steady no matter the demand it just comps by flowing less.
After a lot of searching I would not recommend rheem. Amazon reviews are helpful, go check different models there. Here is mine:
http://www.manualslib.com/manual/255...?page=3#manual
Indyxc is offline   Reply With Quote
Old 01-03-2013, 11:32 AM   #22
Hard water when heated will cause minerals to coat the heating elements in the unit.
Some people like to flush with vinegar or clr one a while to clean the insides.
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Tankless water heater brewmastr Plumbing 2 01-11-2010 09:35 AM
Water heater pressure relief valve confusion Flt_Simulation Plumbing 4 07-11-2009 10:02 AM
Installing a tankless water heater ? bdalekid Plumbing 3 02-26-2007 07:26 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
