I Hear Water Running Through The Pipes, But... - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-24-2008, 12:07 PM   #16
My guess is that they share a vent and vents can transmit sounds a long ways.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 10-24-2008, 04:39 PM   #17
Rewards Points: 858
Maybe I overreacted a bit there<g>
Do you have an automatic sprinkler system in your lawn?
If so, maybe there's a broken pipe, and you don't think it's turning on because no water is coming from the sprinklers.
Also, I often hear water running from a different location than is actually drawing the water. The noise travels very well through pipe, and sometimes just reaches a sort of sound chamber, where you will hear it more loudly, even though it's coming from a different location.
Ultrarunner2017 is online now   Reply With Quote
Old 10-29-2008, 11:01 PM   #18
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
I had my property blue staked, because I needed to plant some trees. I was hoping the water guy would have marked my yard, but he was quick to shoot the street and leave. Two blue arrows that pointed to the meter boxes - Um, WELL DUH!
I don't know if I'll ever figure this mystery out, but I'll keep trying. It doesn't happen much anymore. Maybe it's just coincidence that it only happens when the neighbor's daughter is there. I surely don't want to start a neighbor war, and I'll shut up until I have facts.
And BTW - I was wrong about one of the sheds being over the property line. The other one is, but it doesn't bother me, and I took the free advice of a surveyor (wow - I'm in the wrong business $$$) and judged by where the water and gas lines were. The space between may be considered an easement. As long as I can put my wall up and block their noise I'll be fine. (Yes - these are the "drunk singers" I've mentioned before.)
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Squealing noise when water pipes shut off wrencho Plumbing 2 05-12-2008 11:01 PM
Sump pit filling with water in dry weather dimitar Building & Construction 13 12-19-2007 12:59 PM
Water Heater Leaking at top pipes Cheezhead Plumbing 1 11-20-2007 10:03 PM
Leaky Water Sound 24/7, need your advice. clue89 Plumbing 1 03-02-2007 08:36 AM
NO bath water running!!! rath Plumbing 1 09-09-2005 01:13 PM
