I Hear Water Running In My Pipes 24 Hours. - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-12-2012, 09:18 AM   #16
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Originally Posted by macw View Post
Sorry, what is a water softener? Not to sure what you mean by timer could be stuck in back wash. My electric bill has been tremendous as well, could this be the problem? Could this be the noise that I am hearing?
Journeyman Plumber
Old 03-12-2012, 12:27 PM   #17
Yes I am fearing the worsted! I know already that when I shut the main off in my crawl space where the pipe comes up through the concrete, the running water sound goes away This is without touching the main from the street.
I am having a hard time understanding something, when I turn off the main valve in the crawl space and the sound goes off, wouldn't that mean that the leak is on the house side of the main valve? If the leak was under the crawlspace concrete, by turning off the crawlspace main valve, wouldn't I still hear the water running? Right now when I turn off the cs main valve it goes off/no sound.
Thanks for all of your help, I will keep investigating and will let you know what I or a professional will come up with.
No I don't have a water softener
macw is offline   Reply With Quote
Old 03-12-2012, 12:50 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 814
What do you mean by crawlspace concrete? Do you have a slab down there or are you talking about the foundation? Have you checked all the suggestions put forth so far?
Old 03-12-2012, 01:01 PM   #19
Homerepairguy's Avatar
Rewards Points: 998
Is your house built on a concrete slab or does it have wooden floors?
Homerepairguy is offline   Reply With Quote
Old 03-12-2012, 02:14 PM   #20
Wooden floors. It has a concrete crawlspace.
Old 03-12-2012, 07:24 PM   #21
Rewards Points: 1,668
Check for toilet running due to leaky flush valve. Flush toilet, drop of food dye in tank. See if color ends up in bowl.
Also, if toilet ballcock valve isn't shutting off, water can flow down the overflow tube in the tank, wasting more water.
bob22 is offline   Reply With Quote
Old 03-14-2012, 12:54 AM   #22
Ok, I was wrong when I said I couldn't hear anything when I turned off the main valve (crawlspace). After shutting it off again today, I realized that I could hear running water still, but faintly. So this would most likely mean that I have a leak between the house and the street? I haven't shut the water at the street yet however. But I will asap, to see if the sound goes away completely.
Thanks for all your help guys, really appreciate it. I will keep you posted.
Old 03-14-2012, 07:08 AM   #23
Rewards Points: 152
It's likely but you won't know for sure until you shut off your curb stop at the street. When you put the key on the curbstop, put your ear on it too. You might be able to hear the water whistling by (and stop when you turn the valve off).
Good luck
burnt03 is offline   Reply With Quote
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
I still hear water running when I shut off the main water shut off valve jnut Plumbing 6 07-15-2009 07:46 AM
