Old 08-05-2010, 11:09 PM   #1
I have a sump-pump and a back- up pump with a marine battery. My electricity goes out often due to storms.
What kind of system can I replace the sump-pumps with?
Yvonne Jones is offline   Reply With Quote
Old 08-05-2010, 11:52 PM   #2
If you are on city water check out a high quality water backup pump.
How about a generator that runs on natural gas?
plumberinlaw is online now   Reply With Quote
Old 08-06-2010, 12:32 AM   #3
Wire Chewer
Red Squirrel's Avatar
I ran across this when searching for a way to make a longer lasting source of backup power for my servers, and if it works good, this could possibly be a great solution for a sump pump:
http://www.canadiantire.ca/AST/brows....jsp?locale=en
You can hookup a couple batteries to it and plug it in then plug the sump into it. Not sure how long you get on a single battery though.
A propane or natural gas generator might be a good idea too if the pump is often needed and not just there in case of emergency.
Old 08-06-2010, 07:56 PM   #4
I agree, get a backup gas generator for the house.
handy man88 is offline   Reply With Quote
Old 08-17-2010, 05:55 PM   #5
A backup generator is fine except when the problem is a burned out sump pump or a stuck float switch! Then you can have all the generating power of Niagara Falls and you still get flooded. Get a backup sump pump like a water powered Basepump or a battery powered Hydropump from www.basepump.com and gain the peace of mind it gives you.
Pumpguy is offline   Reply With Quote
Sump Pump Battery BKUP $900. ????? roztom Plumbing 1 11-23-2009 08:53 PM
Sump Pump Questions henlij Plumbing 19 08-12-2009 08:50 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
How does this sump pump system look and how would I add a battery back up? Jay Nel Plumbing 4 07-22-2008 04:48 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
