I Have A Sewer Odor Coming From My Basement In The Laundry Room. - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-25-2011, 12:23 PM   #1
I have a sewer odor coming from my basement in the laundry room.
I have a sewer odor coming from my laundry room in the basement. In the basement I have a kitchen sink, a floor drain, a utility sink, a bathroom sink, a toilet and a shower. The toilet has a new wax ring and I checked to see if it was sealed. The slop sink gets used almost every day, and the toilet gets used very often. I ran water down every drain, and ran all the water in the faucets and it went away for a couple of days and then came back. Now where I live the water goes to I believe a catch basin right outside my house. I pulled the cover and the water is a couple of feet down, but I can still see the plumbing pipes that go inside my house. I am running out of solutiuons here any help would be great. Also I read that all of my sewer lines should be vented, I do not understand that. Should they all be tied into eachother. Thanks In Advance
whitelx1 is offline   Reply With Quote
Old 09-26-2011, 12:51 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
All traps have to be vented after the trap in order for the drain/waste/vent system to work properly. They do not all have to be tied into the same vent stack. (Without a vent, your pipes are like a straw with finger over hte upper end, holding the water.)
There should a trap at every drain that you mentioned (a toilet has a built-in trap), and they all need to be vented in some way or the the water running through nearby drain pipes may siphon a trap dry to create a "vent" if it is not vented properly.
My guess is that one of your vent stacks is partially clogged on the roof.
Go up on the roof and remove any birdnests, leaves, sticks, debris ets. that you can by hand from the vent pipes sticking up through your roof and flush the stack down with a water hose.
That should help solve your trap siphon problem allowing the sewer gas back into your basement.
Good Luck!
Mike Swearingen is offline   Reply With Quote
Old 09-26-2011, 02:47 PM   #3
Lightfoot's Avatar
Rewards Points: 272
did you pour anything in the floor drain? Where i used to live, I had a washroom in the basement, and if i didn't pour water (and a little bleach) in the floor drain about every week, it would either sour and begin smelling, or evaporate and let the sewer gases through. i believe i saw a post on here once that if your pour a little vegetable oil in the drain after the water, it will stay on top and keep the water from evaporating, so you don't have to do it as often. I never tried that (i don't live there anymore) but it makes sense.
Lightfoot is offline   Reply With Quote
Creating a basement laundry room. Mn_Shooter Plumbing 1 01-06-2011 08:02 PM
Convert cistern into a laundry room? 6burgh Building & Construction 5 11-21-2010 06:51 AM
Laundry Room Dimension Question jonathan03 Appliances 1 01-17-2009 10:08 AM
Sewer gas smell in basement when doing laundry on main floor Bornintc Plumbing 1 01-17-2007 11:04 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 03:08 PM
