I Have A R&M Water Group Sn 70124A Water Softener - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2012, 11:02 AM   #1
I have a R&M water group sn 70124A water softener
When I moved into this house a year ago it seemed to be working - at least I needed to replace the salt. I have not replaced salt in at least 3 months and it's still full. How do I test to see if it's working? I removed quite a bit of salt awhile ago and made sure the control panel was working. I have no idea where to begin with testing this. Thank you! Crystal
crystal4293 is offline   Reply With Quote
Old 02-26-2012, 12:30 PM   #2
Water Treatment
Rewards Points: 850
Any way that you could post a photo?
R&M used a few different valves, digital and non digital.
Akpsdvan is offline   Reply With Quote
Old 02-26-2012, 01:02 PM   #3
I wasn't sure what picture you'd want - here is what I took.
I have a R&M water group sn 70124A water softener-water-softener.jpg   I have a R&M water group sn 70124A water softener-water-softener1.jpg
Old 02-26-2012, 01:46 PM   #4
Water Treatment
Rewards Points: 850
That is the Erie valve.
It is a starting point.
Looks to be a meter set up.
The biggest reason for no salt use is a crust that forms in the salt tank so that the salt below the crust is used but the salt above is not able to drop down to fill in the hole left by the salt getting used.
Here is a link to a valve that looks to be really close to yours
http://www.watersoftener-parts.com/s...nuals/2001.pdf
Old 02-26-2012, 02:38 PM   #5
Do I need to remove all of the salt to fix this? I know I saw something online that talked about testing to make sure there was pressure. Something about the line in the brine tank? I can't find that link and am not sure what I need to remove to test?
Old 02-26-2012, 03:13 PM   #6
Water Treatment
Rewards Points: 850
Take a metal rod and push down through the salt.
Another idea would be to take a rubber mallet and bang on the side of the salt tank, if there is a bridge or crust more times than no a few
good bangs will break it loose enough for salt to drop.
Old 02-26-2012, 03:41 PM   #7
OK in the brine tank there is a cylinder in it. If I push down on the lever inside - shouldn't water come out? Right now that's not happening.
Old 02-26-2012, 04:02 PM   #8
Water Treatment
Rewards Points: 850
Then that is good.
When the system is in service , ie water getting treated there should be no flow into the salt tank.
What you where dealing with is the float assembly in the brine well and has NOTHING to do with a salt crust or salt bridge.
The crust or bridge needs to be broken up so that the salt can be dissolved into the water.
Old 02-26-2012, 04:57 PM   #9
We just did that and the salt went down about a foot...so clearly was what you said! Thank you so much. I bought a water test kit (strips) from home depot today. Should I wait a few days to test? How will I know that it is working properly? Thanks again for taking the time to help me! I really appreciate it!
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Need Help Buying a Sediment and Water Softener System. vpr80 Plumbing 10 02-23-2012 10:26 AM
Water Softeners rickglarson Plumbing 1 01-09-2012 04:10 PM
Water softener or water filter Ext290 Plumbing 7 12-26-2011 10:48 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
